Screen turning off
16 Posts 3 Posters 3.3k Views 3 Watching
  • N Offline
    N6NG
    I was reading a resolved discussion about his screen turning off after 15min. I’m having the same problem. It was suggest he installs xscreensaver. I looked around for it but there are several versions of xscreensaver. I downloaded and installed the one for Linux but it doesn’t seem to work. Is there a special xscreensaver for the RPi ?
    Dennis
    S 1 Reply Last reply Aug 1, 2022, 12:54 AM Reply Quote 0
      sdetweil @N6NG
      @N6NG nothing special. but turn off screen blanking on the preferences
      and if u had used my install script, it would have asked you about screen saver.
      u can use the screensaveroff script if u change your mind
      N 1 Reply Last reply Aug 1, 2022, 4:36 AM Reply Quote 0
      • N Offline
        N6NG @sdetweil
        @sdetweil I had the screen blanking off already and I did use you script to install it… It’s not just that the screen goes blank, it’s that the power on the monitor turns off also, so when the screen would wake up because of motion the power is still off on the monitor. I’m thinking it must be something in the monitor setup but I don’t find it… I thought there might be a command to keep the screen alive so the monitor wouldn’t turn off for lack of activity…
        S 1 Reply Last reply Aug 1, 2022, 11:09 AM Reply Quote 0
          sdetweil @N6NG
          @N6NG ah, monitor
          yes, u have an energy star compliant monitor.
          when the input is turned off it MUST power off after 15 mins.
          unless the monitor supports the cec commands, there is no way to turn it back on programmaticly.
          this is why I use a module that hides all the modules instead of turning off the HDMI port.
          I even had a tv that powered off if it was display a blank screen. pain in the rear.
          N 1 Reply Last reply Aug 1, 2022, 5:53 PM Reply Quote 0
          • N Offline
            N6NG @sdetweil
            @sdetweil And which module is that Sam?
            N 1 Reply Last reply Aug 1, 2022, 5:56 PM Reply Quote 0
            • N Offline
              N6NG @N6NG
              @N6NG I’m guessing it’s mm-Hide-All but can you tie that to the Pir sensor so it hides it with no motion?
              S 1 Reply Last reply Aug 1, 2022, 7:11 PM Reply Quote 0
                sdetweil @N6NG
                @N6NG my MMM-SleepWake
                can be triggered by pir(some other module reading pir), or camera
                I use camera, didn’t have PIR when I started this journey…
                N 1 Reply Last reply Aug 1, 2022, 7:45 PM Reply Quote 0
                • N Offline
                  N6NG @sdetweil
                  @sdetweil Ok Sam… again thanks
                  Dennis
                  N 1 Reply Last reply Aug 1, 2022, 9:25 PM Reply Quote 0
                  • N Offline
                    N6NG @N6NG
                    @N6NG I have the MMM-SleepWake installed. I have the config.js installed. Now I have to tie it to the MMM-PIR-Sensor-Lite module.
                    I’ve got the 2lines in the config.js
                    But what is in place of the /external_motion start and end from the PIR module?
                    on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                    on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                    N 1 Reply Last reply Aug 1, 2022, 9:29 PM Reply Quote 0
                    • N Offline
                      N6NG @N6NG
                      @N6NG I also don’t understand how this would keep the Monitor from turning off after 15 minutes? I need to turn off the auto off somehow.
                      S B 2 Replies Last reply Aug 1, 2022, 9:48 PM Reply Quote 0
