    Screen turning off
    16 Posts 3 Posters 5.2k Views 3 Watching
    • N6NGN Offline
      N6NG
      I was reading a resolved discussion about his screen turning off after 15min. I’m having the same problem. It was suggest he installs xscreensaver. I looked around for it but there are several versions of xscreensaver. I downloaded and installed the one for Linux but it doesn’t seem to work. Is there a special xscreensaver for the RPi ?
      Dennis
        sdetweil @N6NG
        @N6NG nothing special. but turn off screen blanking on the preferences
        and if u had used my install script, it would have asked you about screen saver.
        u can use the screensaveroff script if u change your mind
        N6NGN 1 Reply Last reply Reply Quote 0
        • N6NGN Offline
          N6NG @sdetweil
          @sdetweil I had the screen blanking off already and I did use you script to install it… It’s not just that the screen goes blank, it’s that the power on the monitor turns off also, so when the screen would wake up because of motion the power is still off on the monitor. I’m thinking it must be something in the monitor setup but I don’t find it… I thought there might be a command to keep the screen alive so the monitor wouldn’t turn off for lack of activity…
            sdetweil @N6NG
            @N6NG ah, monitor
            yes, u have an energy star compliant monitor.
            when the input is turned off it MUST power off after 15 mins.
            unless the monitor supports the cec commands, there is no way to turn it back on programmaticly.
            this is why I use a module that hides all the modules instead of turning off the HDMI port.
            I even had a tv that powered off if it was display a blank screen. pain in the rear.
            • N6NGN Offline
              N6NG @sdetweil
              @sdetweil And which module is that Sam?
              • N6NGN Offline
                N6NG @N6NG
                @N6NG I’m guessing it’s mm-Hide-All but can you tie that to the Pir sensor so it hides it with no motion?
                  sdetweil @N6NG
                  @N6NG my MMM-SleepWake
                  can be triggered by pir(some other module reading pir), or camera
                  I use camera, didn’t have PIR when I started this journey…
                  • N6NGN Offline
                    N6NG @sdetweil
                    @sdetweil Ok Sam… again thanks
                    Dennis
                    • N6NGN Offline
                      N6NG @N6NG
                      @N6NG I have the MMM-SleepWake installed. I have the config.js installed. Now I have to tie it to the MMM-PIR-Sensor-Lite module.
                      I’ve got the 2lines in the config.js
                      But what is in place of the /external_motion start and end from the PIR module?
                      on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                      on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                      • N6NGN Offline
                        N6NG @N6NG
                        @N6NG I also don’t understand how this would keep the Monitor from turning off after 15 minutes? I need to turn off the auto off somehow.
                          sdetweil @N6NG
                          @N6NG no need for external if you use pir
                          mode is hide( hides all modules or shows all modules.) doesn’t turn off monitor
                          • BKeyportB Offline
                            BKeyport Module Developer @N6NG
                            @N6NG the trick is to keep the monitor active enough to fool it into not triggering it’s eco feature.
                            • N6NGN Offline
                              N6NG
                              @BKeyport and how would you do that?
                              • N6NGN Offline
                                N6NG @N6NG
                                @N6NG I get an error from the line that looks like this.
                                which is line 47 which shows this error.
                                [ERROR] Line 47 column 19: Parsing error: Unexpected token /
                                That’s the / in front of the home/pi/MagicMirror…
                                Can’t see why that would be a problem.
                                  sdetweil @N6NG
                                  @N6NG you are not using a camera, so u don’t need that
                                  the PIR module should signal user_presence, true
                                  and then sleep wake will show the modules ,
                                  user_presence, false, plus the timeout will hide the modules
                                  • N6NGN Offline
                                    N6NG @sdetweil
                                    @sdetweil Thanks Sam… I’ll give it a try…
