    Custom CSS
    11 Posts 3 Posters 7.0k Views 3 Watching
      SoleLo @BKeyport
      @BKeyport This helps quite a bit, I started using the dev tools yesterday “npm start dev” and it really helped. Thanks!
        SoleLo @sdetweil
        @sdetweil That script does help, I already had the file created, but I made note of the script for the future.
          SoleLo @BKeyport
          @BKeyport one of the modules I’m trying to customize doesn’t seem to have “classes” to adjust, unless I’m missing something for example the Percent/ Range section if I wanted to change the margin-top to 150, how would I go about that?
          BKeyportB S 2 Replies Last reply Reply Quote 0
          • BKeyportB Offline
            BKeyport Module Developer @SoleLo
            @SoleLo I’d have to defer to the CSS masters around here. I’m hacky at best at it.
            Maybe we can loop in @shin10 to help, who really helped me with a situation I needed help with.
              sdetweil @SoleLo
              @SoleLo when there isn’t a class, you can still use the selector syntax to get to an element
              .module_name div div
              etc
              here is a cheatsheet I use on determining a selector, the thing before the {
              https://www.w3schools.com/cssref/css_selectors.asp
              currently, there is no syntax for selecting an element that has some content… but :has() is coming…
              a discussion on using css for individual tags
              https://stackoverflow.com/questions/27823405/how-to-override-a-displaynone-property-applied-to-parent-element-in-specific-ch
                SoleLo @sdetweil
                @sdetweil so for the Percent/ Range it would be something like
                .MMM-Teslamate div div
                margin-top: 100px
                  sdetweil @SoleLo
                  @SoleLo i think to get to the div with the link its
                  .MMM-Teslamate div div div
