    Default Weather module still not displaying
    39 Posts 6 Posters 19.9k Views 6 Watching
      sdetweil @Jarhead96097
      @Jarhead96097
      this is on pi, or windows, or ??
      ok, do this
      rm -rf node_modules
      npm install
      #added
      git checkout modules/default/weather/weather.js
      git status
      then try again
      S Jarhead96097J 2 Replies Last reply Reply Quote 1
        Blackeye @Jarhead96097
        @Jarhead96097 Could be the comma after “true” on the last line of config … not necessary, and causes an error when I run a :check
          @Jarhead96097
          I added a command above to restore the original weather.js from the git repo
          Jarhead96097J 1 Reply Last reply Reply Quote 0
          • Jarhead96097J Offline
            Jarhead96097 @sdetweil
            @sdetweil I added “npm audit fix” as there was 1 high severity vulnerability found. It didn’t solve the vulnerability (didn’t try “npm audit fix --force”), and I’m getting the same error.
            Jarhead96097
            S mumblebajM 2 Replies Last reply Reply Quote 0
              @sdetweil Oh, okay. Let me try that updated string of commands…
              Jarhead96097
                @Jarhead96097 please never do audit… causes more problems than it fixes
                Jarhead96097J 1 Reply Last reply Reply Quote 2
                • mumblebajM Offline
                  mumblebaj Module Developer @Jarhead96097
                  @Jarhead96097 Rule of thumb is to never run npm audit fix.
                    sdetweil @mumblebaj
                    @mumblebaj and we have found npm install parms to turn off the warning coming in next release, and already in my scripts.
                    mumblebajM 1 Reply Last reply Reply Quote 2
                      @sdetweil That’s great
                        @sdetweil Good to know…that may be the root cause of all of this. After rebuilding my MM on 2.20.0, I did the npm audit fix. If we can’t get to a resolution in the next few minutes, I’ll chalk this up to a learning experience and do another rebuild.
                        Jarhead96097
                        • O Offline
                          OldSunGuy
                          May I ask how you are using
                          classes: "daytime_scheduler"
                          Are there two instances of
                          daytime_scheduler
                          I use
                          classes: “currentweather”
                          type: “current”
                          and
                          classes: “weatherforcast”
                          type: “forecast”
                          to replace the deprecated modules.
                          Jarhead96097J 1 Reply Last reply Reply Quote 1
                            @Jarhead96097 use my install script
                            see
                              Jarhead96097 @Jarhead96097
                              @sdetweil “On branch master,” and up to date with origin/master. I also meant to reply earlier that this is on a RPI 4B. Unfortunately, still getting the same error and the weather module is not displaying information.
                              I appreciate everyone’s time…but I’m going to cut to the chase and rebuild using your install script.
                              Thanks again for the time, you’re always very helpful, and I appreciate it.
                              Jarhead96097
                                @Jarhead96097 ah, one other question, what is the current node level
                                node --version
                                Jarhead96097J B 2 Replies Last reply Reply Quote 1
                                  @sdetweil sorry, already using your installation script (but no “npm audit fix” this time around).
                                  Jarhead96097
                                    Blackeye @sdetweil
                                    @sdetweil On my RPi4 it’s 16.16.0, and I’m getting the same problems as Jarhead. After an upgrade there’s now just no reaction to starting mm.
                                      sdetweil @Blackeye
                                      @Blackeye can u show the output of the npm start or, if using pm2 , then
                                      pm2 logs --lines=50
                                      how did u do the upgrade?
                                      S B 2 Replies Last reply Reply Quote 0
                                        @Blackeye also, can u show me the contents of line 159 from
                                        ~/MagicMirror/modules/default/weather/weather.js
                                          Jarhead96097 @OldSunGuy
                                          @OldSunGuy I use the MMM-ModuleScheduler 3rd party module to control when my MM turns off everything except the clock and dims the display at night. “daytime_scheduler” is the class I used to turn off those modules at night.
                                          Jarhead96097
                                            @sdetweil here is what my weather.js (newly rebuilt, but not yet configured) has on lines 148 to 166:
                                            	// What to do when the weather provider has new information available?
                                            	updateAvailable: function () {
                                            		Log.log("New weather information available.");
                                            		this.updateDom(0);
                                            		this.scheduleUpdate();
                                            		if (this.weatherProvider.currentWeather()) {
                                            			this.sendNotification("CURRENTWEATHER_TYPE", { type: this.weatherProvider.currentWeather().weatherType.replace("-", "_") });
                                            		const notificationPayload = {
                                            			currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,
                                            			forecastArray: this.weatherProvider?.weatherForecastArray?.map((ar) => ar.simpleClone()) ?? [],
                                            			hourlyArray: this.weatherProvider?.weatherHourlyArray?.map((ar) => ar.simpleClone()) ?? [],
                                            			locationName: this.weatherProvider?.fetchedLocationName,
                                            			providerName: this.weatherProvider.providerName
                                            		this.sendNotification("WEATHER_UPDATED", notificationPayload);
                                            Jarhead96097
                                            Jarhead96097J S 2 Replies Last reply Reply Quote 0
