    Default Weather module still not displaying
    39 Posts 6 Posters 20.4k Views 6 Watching
      @Jarhead96097
      I added a command above to restore the original weather.js from the git repo
      Jarhead96097J 1 Reply Last reply Reply Quote 0
      • Jarhead96097J
        Jarhead96097 @sdetweil
        @sdetweil I added “npm audit fix” as there was 1 high severity vulnerability found. It didn’t solve the vulnerability (didn’t try “npm audit fix --force”), and I’m getting the same error.
        Jarhead96097
        S mumblebajM 2 Replies Last reply Reply Quote 0
        • Jarhead96097J
          @sdetweil Oh, okay. Let me try that updated string of commands…
          Jarhead96097
            sdetweil @Jarhead96097
            @Jarhead96097 please never do audit… causes more problems than it fixes
            Jarhead96097J 1 Reply Last reply Reply Quote 2
            • mumblebajM
              mumblebaj Module Developer @Jarhead96097
              @Jarhead96097 Rule of thumb is to never run npm audit fix.
                sdetweil @mumblebaj
                @mumblebaj and we have found npm install parms to turn off the warning coming in next release, and already in my scripts.
                mumblebajM 1 Reply Last reply Reply Quote 2
                • mumblebajM
                  @sdetweil That’s great
                  • Jarhead96097J
                    @sdetweil Good to know…that may be the root cause of all of this. After rebuilding my MM on 2.20.0, I did the npm audit fix. If we can’t get to a resolution in the next few minutes, I’ll chalk this up to a learning experience and do another rebuild.
                    Jarhead96097
                    • O
                      OldSunGuy
                      May I ask how you are using
                      classes: "daytime_scheduler"
                      Are there two instances of
                      daytime_scheduler
                      I use
                      classes: “currentweather”
                      type: “current”
                      and
                      classes: “weatherforcast”
                      type: “forecast”
                      to replace the deprecated modules.
                      Jarhead96097J 1 Reply Last reply Reply Quote 1
                        @Jarhead96097 use my install script
                        see
                        • Jarhead96097J
                          Jarhead96097 @Jarhead96097
                          @sdetweil “On branch master,” and up to date with origin/master. I also meant to reply earlier that this is on a RPI 4B. Unfortunately, still getting the same error and the weather module is not displaying information.
                          I appreciate everyone’s time…but I’m going to cut to the chase and rebuild using your install script.
                          Thanks again for the time, you’re always very helpful, and I appreciate it.
                          Jarhead96097
                            @Jarhead96097 ah, one other question, what is the current node level
                            node --version
                            Jarhead96097J B 2 Replies Last reply Reply Quote 1
                            • Jarhead96097J
                              @sdetweil sorry, already using your installation script (but no “npm audit fix” this time around).
                              Jarhead96097
                                Blackeye @sdetweil
                                @sdetweil On my RPi4 it’s 16.16.0, and I’m getting the same problems as Jarhead. After an upgrade there’s now just no reaction to starting mm.
                                  sdetweil @Blackeye
                                  @Blackeye can u show the output of the npm start or, if using pm2 , then
                                  pm2 logs --lines=50
                                  how did u do the upgrade?
                                  S B 2 Replies Last reply Reply Quote 0
                                    @Blackeye also, can u show me the contents of line 159 from
                                    ~/MagicMirror/modules/default/weather/weather.js
                                    • Jarhead96097J
                                      Jarhead96097 @OldSunGuy
                                      @OldSunGuy I use the MMM-ModuleScheduler 3rd party module to control when my MM turns off everything except the clock and dims the display at night. “daytime_scheduler” is the class I used to turn off those modules at night.
                                      Jarhead96097
                                      • Jarhead96097J
                                        @sdetweil here is what my weather.js (newly rebuilt, but not yet configured) has on lines 148 to 166:
                                        	// What to do when the weather provider has new information available?
                                        	updateAvailable: function () {
                                        		Log.log("New weather information available.");
                                        		this.updateDom(0);
                                        		this.scheduleUpdate();
                                        		if (this.weatherProvider.currentWeather()) {
                                        			this.sendNotification("CURRENTWEATHER_TYPE", { type: this.weatherProvider.currentWeather().weatherType.replace("-", "_") });
                                        		const notificationPayload = {
                                        			currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,
                                        			forecastArray: this.weatherProvider?.weatherForecastArray?.map((ar) => ar.simpleClone()) ?? [],
                                        			hourlyArray: this.weatherProvider?.weatherHourlyArray?.map((ar) => ar.simpleClone()) ?? [],
                                        			locationName: this.weatherProvider?.fetchedLocationName,
                                        			providerName: this.weatherProvider.providerName
                                        		this.sendNotification("WEATHER_UPDATED", notificationPayload);
                                        Jarhead96097
                                        Jarhead96097J S 2 Replies Last reply Reply Quote 0
                                        • Jarhead96097J
                                          @sdetweil Sam, thanks for all of your help. I’ve finished rebuilding without running ‘npm audit fix’ and everything is working as it should! I used your installation script and everything worked fine. I also took the opportunity to move things around and try a couple of new 3rd party modules… everything is back to normal!
                                          Thanks again,
                                          Jarhead96097
                                          Jarhead96097
                                            @Jarhead96097 said in Default Weather module still not displaying:
                                            thats line 158 and159.
                                            the only thing i can think of is the ?. (optional chaining) operator…
                                            but its been long supported… and it works on my 16.9.1 node version
                                            see item 2 in the list here
                                            https://www.freecodecamp.org/news/how-the-question-mark-works-in-javascript/
