    Installed on Raspabrry pi4b with magic mirror os modules go back to default after restart
    11 Posts 4 Posters 4.1k Views 4 Watching
    • O Offline
      omnismarthome
      • karsten13K Offline
        karsten13 @omnismarthome
        @omnismarthome
        you have to add MM_OVERRIDE_DEFAULT_MODULES: "false" in the existing environment: section:
        version: '3'
        services:
          magicmirror:
            container_name: mm
            image: karsten13/magicmirror:latest
            volumes:
              - ../mounts/config:/opt/magic_mirror/config
              - ../mounts/modules:/opt/magic_mirror/modules
              - ../mounts/css:/opt/magic_mirror/css
              - /tmp/.X11-unix:/tmp/.X11-unix
              - /opt/vc:/opt/vc/:ro
              - /usr/bin/vcgencmd:/usr/bin/vcgencmd
              - /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket
            devices:
              - /dev/vchiq
            environment:
              LD_LIBRARY_PATH: /opt/vc/lib
              DISPLAY: unix:0.0
            network_mode: host
            shm_size: "128mb"
            restart: unless-stopped
            command:
              - npm
              - run
              - start
        • O Offline
          omnismarthome
          I have added as per your guide line however the issue still persist
          Thanks for your kind support
          the file i am editing is under the following folder
          /home/pi/magicmirror/run
          • O Offline
            omnismarthome
            issue seems to be with compliment module
              sdetweil @omnismarthome
              @omnismarthome the config for compliments is in the config.js, right? NOT editing this module source file (which could be replaced)
              never edit the module source files.
              • O Offline
                omnismarthome
                  @omnismarthome NO>>>>>>>>
                  only where the config.js is located
                        module: "compliments",
                        position:" ?????",
                              compliments: {
                                      anytime: [........],
                                       etc
                  • S sdetweil moved this topic from Tutorials on
                  • O Offline
                    omnismarthome
                    thanks for the help fixed :)
                      MMRIZE @omnismarthome
                      @omnismarthome
                      Out of the topic question. You might have a non-usual resolution screen. Can I ask which kind of screen you are using in the above screenshot?
