    Installed on Raspabrry pi4b with magic mirror os modules go back to default after restart
    11 Posts 4 Posters 4.1k Views 4 Watching
    • O Offline
      omnismarthome
      I installed via following Magic Mirror OS
      i can boot and get display with SD card but when i make changes to the modules and restart the revert back to default …
      Please help
      https://github.com/guysoft/MagicMirrorOS
      • karsten13K Offline
        karsten13 @omnismarthome
        see https://khassel.gitlab.io/magicmirror/configuration/
        • O Offline
          omnismarthome
            @omnismarthome
            you have to add MM_OVERRIDE_DEFAULT_MODULES: "false" in the existing environment: section:
            version: '3'
            services:
              magicmirror:
                container_name: mm
                image: karsten13/magicmirror:latest
                volumes:
                  - ../mounts/config:/opt/magic_mirror/config
                  - ../mounts/modules:/opt/magic_mirror/modules
                  - ../mounts/css:/opt/magic_mirror/css
                  - /tmp/.X11-unix:/tmp/.X11-unix
                  - /opt/vc:/opt/vc/:ro
                  - /usr/bin/vcgencmd:/usr/bin/vcgencmd
                  - /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket
                devices:
                  - /dev/vchiq
                environment:
                  LD_LIBRARY_PATH: /opt/vc/lib
                  DISPLAY: unix:0.0
                network_mode: host
                shm_size: "128mb"
                restart: unless-stopped
                command:
                  - npm
                  - run
                  - start
            • O Offline
              omnismarthome
              I have added as per your guide line however the issue still persist
              Thanks for your kind support
              the file i am editing is under the following folder
              /home/pi/magicmirror/run
              • O Offline
                omnismarthome
                issue seems to be with compliment module
                  sdetweil @omnismarthome
                  @omnismarthome the config for compliments is in the config.js, right? NOT editing this module source file (which could be replaced)
                  never edit the module source files.
                  • O Offline
                    omnismarthome
                      @omnismarthome NO>>>>>>>>
                      only where the config.js is located
                            module: "compliments",
                            position:" ?????",
                                  compliments: {
                                          anytime: [........],
                                           etc
                      • S sdetweil moved this topic from Tutorials on
                      • O Offline
                        omnismarthome
                        thanks for the help fixed :)
                          MMRIZE @omnismarthome
                          @omnismarthome
                          Out of the topic question. You might have a non-usual resolution screen. Can I ask which kind of screen you are using in the above screenshot?
