Installed on Raspabrry pi4b with magic mirror os modules go back to default after restart
11 Posts 4 Posters 3.5k Views 4 Watching
  • O Offline
    omnismarthome
    I installed via following Magic Mirror OS
    i can boot and get display with SD card but when i make changes to the modules and restart the revert back to default …
    Please help
    https://github.com/guysoft/MagicMirrorOS
    K 1 Reply Last reply Aug 8, 2022, 7:44 PM Reply Quote 0
    • K Online
      karsten13 @omnismarthome
      see https://khassel.gitlab.io/magicmirror/configuration/
      • O Offline
        omnismarthome
        K 1 Reply Last reply Aug 8, 2022, 8:46 PM Reply Quote 0
        • K Online
          @omnismarthome
          you have to add MM_OVERRIDE_DEFAULT_MODULES: "false" in the existing environment: section:
          version: '3'
          services:
            magicmirror:
              container_name: mm
              image: karsten13/magicmirror:latest
              volumes:
                - ../mounts/config:/opt/magic_mirror/config
                - ../mounts/modules:/opt/magic_mirror/modules
                - ../mounts/css:/opt/magic_mirror/css
                - /tmp/.X11-unix:/tmp/.X11-unix
                - /opt/vc:/opt/vc/:ro
                - /usr/bin/vcgencmd:/usr/bin/vcgencmd
                - /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket
              devices:
                - /dev/vchiq
              environment:
                LD_LIBRARY_PATH: /opt/vc/lib
                DISPLAY: unix:0.0
              network_mode: host
              shm_size: "128mb"
              restart: unless-stopped
              command:
                - npm
                - run
                - start
          • O Offline
            omnismarthome
            I have added as per your guide line however the issue still persist
            Thanks for your kind support
            the file i am editing is under the following folder
            /home/pi/magicmirror/run
            • O Offline
              omnismarthome
              issue seems to be with compliment module
              S 1 Reply Last reply Aug 8, 2022, 9:18 PM Reply Quote 0
                sdetweil @omnismarthome
                @omnismarthome the config for compliments is in the config.js, right? NOT editing this module source file (which could be replaced)
                never edit the module source files.
                • O Offline
                  omnismarthome
                  S 1 Reply Last reply Aug 8, 2022, 9:43 PM Reply Quote 0
                    @omnismarthome NO>>>>>>>>
                    only where the config.js is located
                          module: "compliments",
                          position:" ?????",
                                compliments: {
                                        anytime: [........],
                                         etc
                    • S sdetweil moved this topic from Tutorials on Aug 8, 2022, 10:14 PM
                    • O Offline
                      omnismarthome
                      thanks for the help fixed :)
                      M 1 Reply Last reply Aug 9, 2022, 6:30 AM Reply Quote 0
