    Installed on Raspabrry pi4b with magic mirror os modules go back to default after restart
    11 Posts 4 Posters 4.0k Views 4 Watching
    • O Offline
      omnismarthome
      I have added as per your guide line however the issue still persist
      Thanks for your kind support
      the file i am editing is under the following folder
      /home/pi/magicmirror/run
      • O Offline
        omnismarthome
        issue seems to be with compliment module
          sdetweil @omnismarthome
          @omnismarthome the config for compliments is in the config.js, right? NOT editing this module source file (which could be replaced)
          never edit the module source files.
          • O Offline
            omnismarthome
              @omnismarthome NO>>>>>>>>
              only where the config.js is located
                    module: "compliments",
                    position:" ?????",
                          compliments: {
                                  anytime: [........],
                                   etc
              • S sdetweil moved this topic from Tutorials on
              • O Offline
                omnismarthome
                thanks for the help fixed :)
                  MMRIZE @omnismarthome
                  @omnismarthome
                  Out of the topic question. You might have a non-usual resolution screen. Can I ask which kind of screen you are using in the above screenshot?
