    RPI 3B keeps going to blank screen (cursor showing)
    27 Posts 5 Posters 9.5k Views 5 Watching
      BigTJ
      Re: new script for screensaver disable
      Hi all,
      I’m having a big problem with my magic mirror. It looks as though my RPI 3B keeps going into screensave. After a while I get a black screen with a white arrow cursor.
      I have gone through all the usual documented ways of turning off screen save ie
      consoleblank=0 in cmdline.txt,
      Screen Blanking’ option in the Raspberry Pi Configuration tool,
      Xscreensaver is not installed,
      Adding to /etc/xdg/lxsession/LXDE/autostart;-
      @xset s noblank
      @xset s off
      @xset -dpms,
      Adding to /etc/kbd/config;-
      BLANK_TIME=0
      POWERDOWN_TIME=0,
      Adding to ~/.bashrc;- setterm -blank 0 -powerdown 0,
      Adding to /etc/lightdm/lightdm.conf;- xserver-command=X -s 0 -p 0 -dpms,
      etc etc…
      If I connect using VPN I still only see a black screen with cursor.
      Any help with this really frustrating problem would be greatly appreciated.
      @sdetweil - I found references to an old script of yours but could not access it to try it on my MM.
      BigTJ
        sdetweil @BigTJ
        @BigTJ see the screensaveroff script at the bottom of the page here
          BigTJ
          Many thanks
          I ran your script with the following result;-
          disable screensaver via gsettings was true and uint32 300
          disable screensaver via lightdm.conf
          lxsession screen saver already disabled
          Does this mean the screensaver is already off or that the script has disabled the screensaver?
          Thanks again
          BigTJ
            sdetweil @BigTJ
            @BigTJ script has disabled
              BigTJ
              Thanks for your help.
              This has been a problem for a long time. The mirror is being used headless so having to restart over and over again has spoilt the usefulness of the mirror. Hopefully that is all sorted.
              Will let you know after testing.
              Thanks again.
              BigTJ
                BigTJ
                @sdetweil Unfortunately I am still getting the black screen with mouse cursor.
                I’ve installed a new OS from scratch and Installed a clean version of MM, installed the modules from scratch but the problem persists.
                When the MM has gone to black screen I cannot use CtrlM to minimise the MM window but I can use CtrlR to force a re-read and this brings the MM back on. Any ideas what can be causing this?
                BigTJ
                S karsten13K 2 Replies Last reply Reply Quote 0
                  sdetweil @BigTJ
                  @BigTJ show the messages from where u start MagicMirror at the time of the failure
                  • karsten13K Online
                    karsten13 @BigTJ
                    @BigTJ
                    which modules have you installed?
                      BigTJ @sdetweil
                      @sdetweil Hi, the messages of note from starting MM are as below
                      setterm: terminal xterm-256color does not support --blank
                      pi@raspberrypi:~ $ cd MagicMirror
                      pi@raspberrypi:~/MagicMirror $ npm start run
                      magicmirror@2.18.0 start
                      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “run”
                      [24.08.2022 18:40.30.154] [LOG] Starting MagicMirror: v2.18.0
                      [24.08.2022 18:40.30.166] [LOG] Loading config …
                      [24.08.2022 18:40.30.198] [LOG] Loading module helpers …
                      [24.08.2022 18:40.30.206] [LOG] No helper found for module: alert.
                      [24.08.2022 18:40.31.907] [LOG] Initializing new module helper …
                      [24.08.2022 18:40.31.911] [LOG] Module helper loaded: MMM-Wallpaper
                      [24.08.2022 18:40.31.917] [LOG] No helper found for module: clock.
                      [24.08.2022 18:40.31.922] [LOG] No helper found for module: calendar_monthly.
                      [24.08.2022 18:40.32.330] [LOG] Initializing new module helper …
                      [24.08.2022 18:40.32.332] [LOG] Module helper loaded: calendar
                      [24.08.2022 18:40.32.336] [LOG] No helper found for module: weather.
                      [24.08.2022 18:40.32.341] [LOG] No helper found for module: MMM-WiFiPassword.
                      [24.08.2022 18:40.32.421] [LOG] Initializing new module helper …
                      [24.08.2022 18:40.32.422] [LOG] Module helper loaded: newsfeed
                      [24.08.2022 18:40.32.425] [LOG] All module helpers loaded.
                      [24.08.2022 18:40.32.697] [LOG] Starting server on port 8080 …
                      [24.08.2022 18:40.32.740] [LOG] Server started …
                      [24.08.2022 18:40.32.743] [LOG] Connecting socket for: MMM-Wallpaper
                      [24.08.2022 18:40.32.745] [LOG] Starting node helper for: MMM-Wallpaper
                      [24.08.2022 18:40.32.746] [LOG] Connecting socket for: calendar
                      [24.08.2022 18:40.32.748] [LOG] Starting node helper for: calendar
                      [24.08.2022 18:40.32.749] [LOG] Connecting socket for: newsfeed
                      [24.08.2022 18:40.32.750] [LOG] Starting node helper for: newsfeed
                      [24.08.2022 18:40.32.751] [LOG] Sockets connected & modules started …
                      [24.08.2022 18:40.33.378] [LOG] Launching application.
                      [24055:0824/184036.476041:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                      [24096:0824/184036.932766:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                      [24.08.2022 18:40.40.506] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics - Interval: 3000000
                      [24.08.2022 18:40.40.693] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics - Interval: 3000000
                      [24.08.2022 18:40.40.703] [LOG] Create new newsfetcher for url: http://feeds.bbci.co.uk/news/uk/rss.xml - Interval: 300000
                      [24.08.2022 23:05.55.239] [INFO] Newsfeed-Fetcher: Broadcasting 38 items.
                      [24067:0824/230903.755884:ERROR:broker_posix.cc(46)] Received unexpected number of handles
                      [24.08.2022 23:10.55.583] [INFO] Newsfeed-Fetcher: Broadcasting 38 items.
                      I don’t know exactly when the black screen occurred.
                      Hope this helps
                      Thanks BigTJ
                        BigTJ
                        @karsten13 The modules of the MM are listed below in shortened form. Thanks for your interest.
                        “alert”
                        “updatenotification”
                        “MMM-Wallpaper”
                        “clock”
                        “calendar_monthly”
                        “calendar”
                        header: “Steve’s Upcoming Items”
                        “MMM-GoogleSheets”
                        “calendar”
                        — header: “Angela’s Upcoming Items”
                        “weather”
                        — position: “top_left”
                        — header: "Currently: "
                        — location: “Doncaster”
                        “weather”,
                        — header: “Forecast”
                        “weather”,
                        — location: “Pickering”
                        ‘MMM-WiFiPassword’
                        “newsfeed”
