    RPI 3B keeps going to blank screen (cursor showing)
    27 Posts 5 Posters 9.8k Views 5 Watching
      sdetweil @BigTJ
      @BigTJ see the screensaveroff script at the bottom of the page here
        BigTJ
        Many thanks
        I ran your script with the following result;-
        disable screensaver via gsettings was true and uint32 300
        disable screensaver via lightdm.conf
        lxsession screen saver already disabled
        Does this mean the screensaver is already off or that the script has disabled the screensaver?
        Thanks again
        BigTJ
          sdetweil @BigTJ
          @BigTJ script has disabled
            BigTJ
            Thanks for your help.
            This has been a problem for a long time. The mirror is being used headless so having to restart over and over again has spoilt the usefulness of the mirror. Hopefully that is all sorted.
            Will let you know after testing.
            Thanks again.
            BigTJ
              BigTJ
              @sdetweil Unfortunately I am still getting the black screen with mouse cursor.
              I’ve installed a new OS from scratch and Installed a clean version of MM, installed the modules from scratch but the problem persists.
              When the MM has gone to black screen I cannot use CtrlM to minimise the MM window but I can use CtrlR to force a re-read and this brings the MM back on. Any ideas what can be causing this?
              BigTJ
              S karsten13K 2 Replies Last reply Reply Quote 0
                sdetweil @BigTJ
                @BigTJ show the messages from where u start MagicMirror at the time of the failure
                • karsten13K Online
                  karsten13 @BigTJ
                  @BigTJ
                  which modules have you installed?
                    BigTJ @sdetweil
                    @sdetweil Hi, the messages of note from starting MM are as below
                    setterm: terminal xterm-256color does not support --blank
                    pi@raspberrypi:~ $ cd MagicMirror
                    pi@raspberrypi:~/MagicMirror $ npm start run
                    magicmirror@2.18.0 start
                    DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “run”
                    [24.08.2022 18:40.30.154] [LOG] Starting MagicMirror: v2.18.0
                    [24.08.2022 18:40.30.166] [LOG] Loading config …
                    [24.08.2022 18:40.30.198] [LOG] Loading module helpers …
                    [24.08.2022 18:40.30.206] [LOG] No helper found for module: alert.
                    [24.08.2022 18:40.31.907] [LOG] Initializing new module helper …
                    [24.08.2022 18:40.31.911] [LOG] Module helper loaded: MMM-Wallpaper
                    [24.08.2022 18:40.31.917] [LOG] No helper found for module: clock.
                    [24.08.2022 18:40.31.922] [LOG] No helper found for module: calendar_monthly.
                    [24.08.2022 18:40.32.330] [LOG] Initializing new module helper …
                    [24.08.2022 18:40.32.332] [LOG] Module helper loaded: calendar
                    [24.08.2022 18:40.32.336] [LOG] No helper found for module: weather.
                    [24.08.2022 18:40.32.341] [LOG] No helper found for module: MMM-WiFiPassword.
                    [24.08.2022 18:40.32.421] [LOG] Initializing new module helper …
                    [24.08.2022 18:40.32.422] [LOG] Module helper loaded: newsfeed
                    [24.08.2022 18:40.32.425] [LOG] All module helpers loaded.
                    [24.08.2022 18:40.32.697] [LOG] Starting server on port 8080 …
                    [24.08.2022 18:40.32.740] [LOG] Server started …
                    [24.08.2022 18:40.32.743] [LOG] Connecting socket for: MMM-Wallpaper
                    [24.08.2022 18:40.32.745] [LOG] Starting node helper for: MMM-Wallpaper
                    [24.08.2022 18:40.32.746] [LOG] Connecting socket for: calendar
                    [24.08.2022 18:40.32.748] [LOG] Starting node helper for: calendar
                    [24.08.2022 18:40.32.749] [LOG] Connecting socket for: newsfeed
                    [24.08.2022 18:40.32.750] [LOG] Starting node helper for: newsfeed
                    [24.08.2022 18:40.32.751] [LOG] Sockets connected & modules started …
                    [24.08.2022 18:40.33.378] [LOG] Launching application.
                    [24055:0824/184036.476041:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                    [24096:0824/184036.932766:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                    [24.08.2022 18:40.40.506] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics - Interval: 3000000
                    [24.08.2022 18:40.40.693] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/*********gmail.com/private-*********/basic.ics - Interval: 3000000
                    [24.08.2022 18:40.40.703] [LOG] Create new newsfetcher for url: http://feeds.bbci.co.uk/news/uk/rss.xml - Interval: 300000
                    [24.08.2022 23:05.55.239] [INFO] Newsfeed-Fetcher: Broadcasting 38 items.
                    [24067:0824/230903.755884:ERROR:broker_posix.cc(46)] Received unexpected number of handles
                    [24.08.2022 23:10.55.583] [INFO] Newsfeed-Fetcher: Broadcasting 38 items.
                    I don’t know exactly when the black screen occurred.
                    Hope this helps
                    Thanks BigTJ
                      BigTJ
                      @karsten13 The modules of the MM are listed below in shortened form. Thanks for your interest.
                      “alert”
                      “updatenotification”
                      “MMM-Wallpaper”
                      “clock”
                      “calendar_monthly”
                      “calendar”
                      header: “Steve’s Upcoming Items”
                      “MMM-GoogleSheets”
                      “calendar”
                      — header: “Angela’s Upcoming Items”
                      “weather”
                      — position: “top_left”
                      — header: "Currently: "
                      — location: “Doncaster”
                      “weather”,
                      — header: “Forecast”
                      “weather”,
                      — location: “Pickering”
                      ‘MMM-WiFiPassword’
                      “newsfeed”
                      • karsten13K Online
                        karsten13 @BigTJ
                        @BigTJ
                        I asked because I had problems with some modules which needed to much memory which results also in a black screen with white cursor.
                        You could try to run without the 3 foreign modules to see if the problem persists.
