    MMM-OpenWeatherMapForecast stuck on Loading....
    63 Posts 16 Posters 55.8k Views 18 Watching
      sdetweil @ally
      @ally i used your config from
      https://forum.magicmirror.builders/topic/17141/mmm-openweathermapforecast-stuck-on-loading/1?_=1661513140571
      with my openweather apikey and it worked without issue.
        sdetweil @ally
        @ally edit the node_helper.js of the module and change this
                            } else {
                                console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
        to this
                            } else {
                                if(response.statusCode != 200)
                                console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** bad status ** " + response.statusCode);
                                    else
        • A
          ally @sdetweil
          @sdetweil any thoughts on why this is occurring on a fresh install of MM and this module? I also just checked the MM change logs and i am definitely running the latest version (## [2.20.0] - 2022-07-02).
          Ally
            sdetweil @ally
            @ally no idea. but without the code change, we won’t know what the error is…
            only thing I can think of is the apikey has a leading or trailing space, making it bad
            A 1 Reply Last reply
            • A
              ally @sdetweil
              @sdetweil yeah, I was worried that might be the case as well, which is why I went to a fresh install and left the original weather module using the same key.
              Same key, same quotes, no spaces, default settings and this is the result.
              Config is setup for default weather module current, then forecast and then MMM-OpenWeatherMapForecast, which is stuck on Loading.
                sdetweil @ally
                @ally again need the startup messages w the new code
                I copy/pasted the config u supplied exactly and change to my API key and it worked as expected. so it’s not a config problem.
                it’s an apikey problem
                • A
                  ally @sdetweil
                  @sdetweil I deleted the old api key and made a new one, same result. The default weather modules load and this one doesn’t.
                    sdetweil @ally
                    @ally what is the message from the terminal window w the new code?
                      stevengill @ally
                      @ally I removed the location name (e.g. New York) and just used the locationID number and it started to work
                        sdetweil @stevengill
                        @stevengill he doesn’t have location specified with the weathermap module
                          stevengill @sdetweil
                          @sdetweil sorry, I must have misread this and thought this was their code
                          • A
                            ally @sdetweil
                            @sdetweil This is new.
                            oad stylesheet: modules/MMM-OpenWeatherMapForecast/MMM-OpenWeatherMapForecast.css
                            loader.js:162 Styles loaded for: MMM-OpenWeatherMapForecast
                            loader.js:164 Translations loaded for: MMM-OpenWeatherMapForecast
                            loader.js:184 Load script: modules/default/newsfeed/newsfeed.js
                            module.js:509 Module registered: newsfeed
                            loader.js:155 Bootstrapping module: newsfeed
                            loader.js:244 File already loaded: moment.js
                            loader.js:160 Scripts loaded for: newsfeed
                            loader.js:203 Load stylesheet: modules/default/newsfeed/newsfeed.css
                            loader.js:162 Styles loaded for: newsfeed
                            loader.js:164 Translations loaded for: newsfeed
                            loader.js:203 Load stylesheet: css/custom.css
                            alert.js:47 Starting module: alert
                            updatenotification.js:18 Starting module: updatenotification
                            clock.js:48 Starting module: clock
                            calendar.js:87 Starting module: calendar
                            compliments.js:38 Starting module: compliments
                            weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
                            weatherprovider.js:46 Weather provider: OpenWeatherMap started.
                            MMM-OpenWeatherMapForecast.js:145 Starting module: MMM-OpenWeatherMapForecast
                            newsfeed.js:65 Starting module: newsfeed
                            main.js:501 All modules started!
                            openweathermap.js:63 Could not load data ...  XMLHttpRequest
                            (anonymous) @ openweathermap.js:63
                            weather.js:150 New weather information available.
                            openweathermap.js:43 Could not load data ...  XMLHttpRequest
                            (anonymous) @ openweathermap.js:43
                            59weather.js:150 New weather information available.
                              sdetweil @ally
                              @ally those errors are from the default weather module…
                              i think you should disable them while we work this
                              add
                              disabled: true,
                              after the module:“weather”,
                              lines
                              • A
                                ally @sdetweil
                                @sdetweil No errors being reported, but no change in the modules behavior.
                                			module: "weather",
                                			disabled: true,
                                				type: "current",
                                				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                				apiKey: "XXXXXXXXXXX"
                                			module: "weather",
                                			disabled: true,
                                			header: "Weather Forecast",
                                				type: "forecast",
                                			module: "MMM-OpenWeatherMapForecast",
                                			header: "Weather",
                                			classes: "default everyone",
                                			disabled: false,
                                				apikey: "XXXXXXXXXXX",
                                				latitude: "51.506130",
                                				longitude: "-0.090270",
                                  sdetweil @ally
                                  @ally I need the messages from the terminal window or pm2 logs
                                  do
                                  pm2 flush
                                  pm2 restart 0
                                  wait
                                  pm2 logs --lines=80 >somefile.txt 2>&1
                                  ctrl-c
                                  then examine somefile.txt
                                  • A
                                    ally @sdetweil
                                    @sdetweil unfortunately the same useful answer
                                    /home/pi/.pm2/logs/MagicMirror-out.log last 80 lines:
                                    0|MagicMir |
                                    0|MagicMir | > magicmirror@2.20.0 start
                                    0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                    0|MagicMir |
                                    0|MagicMir | [28.08.2022 20:52.28.785] [LOG]   Starting MagicMirror: v2.20.0
                                    0|MagicMir | [28.08.2022 20:52.28.793] [LOG]   Loading config ...
                                    0|MagicMir | [28.08.2022 20:52.28.800] [LOG]   Loading module helpers ...
                                    0|MagicMir | [28.08.2022 20:52.28.803] [LOG]   No helper found for module: alert.
                                    0|MagicMir | [28.08.2022 20:52.28.823] [LOG]   Initializing new module helper ...
                                    0|MagicMir | [28.08.2022 20:52.28.825] [LOG]   Module helper loaded: updatenotification
                                    0|MagicMir | [28.08.2022 20:52.28.826] [LOG]   No helper found for module: clock.
                                    0|MagicMir | [28.08.2022 20:52.29.043] [LOG]   Initializing new module helper ...
                                    0|MagicMir | [28.08.2022 20:52.29.044] [LOG]   Module helper loaded: calendar
                                    0|MagicMir | [28.08.2022 20:52.29.046] [LOG]   No helper found for module: compliments.
                                    0|MagicMir | [28.08.2022 20:52.29.097] [LOG]   Initializing new module helper ...
                                    0|MagicMir | [28.08.2022 20:52.29.098] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                                    0|MagicMir | [28.08.2022 20:52.29.129] [LOG]   Initializing new module helper ...
                                    0|MagicMir | [28.08.2022 20:52.29.131] [LOG]   Module helper loaded: newsfeed
                                    0|MagicMir | [28.08.2022 20:52.29.132] [LOG]   All module helpers loaded.
                                    0|MagicMir | [28.08.2022 20:52.29.246] [LOG]   Starting server on port 8080 ...
                                    0|MagicMir | [28.08.2022 20:52.29.264] [LOG]   Server started ...
                                    0|MagicMir | [28.08.2022 20:52.29.265] [LOG]   Connecting socket for: updatenotification
                                    0|MagicMir | [28.08.2022 20:52.29.267] [LOG]   Starting module helper: updatenotification
                                    0|MagicMir | [28.08.2022 20:52.29.268] [LOG]   Connecting socket for: calendar
                                    0|MagicMir | [28.08.2022 20:52.29.268] [LOG]   Starting node helper for: calendar
                                    0|MagicMir | [28.08.2022 20:52.29.269] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                                    0|MagicMir | [28.08.2022 20:52.29.270] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                                    0|MagicMir | [28.08.2022 20:52.29.271] [LOG]   Connecting socket for: newsfeed
                                    0|MagicMir | [28.08.2022 20:52.29.271] [LOG]   Starting node helper for: newsfeed
                                    0|MagicMir | [28.08.2022 20:52.29.272] [LOG]   Sockets connected & modules started ...
                                    0|MagicMir | [28.08.2022 20:52.29.554] [LOG]   Launching application.
                                    0|MagicMir | [28.08.2022 20:52.32.673] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                    0|MagicMir | [28.08.2022 20:52.33.281] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                    0|MagicMir | [28.08.2022 20:52.33.308] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                                    0|MagicMir | [28.08.2022 20:52.33.374] [INFO]  Checking git for module: default
                                    0|MagicMir | [28.08.2022 20:52.33.661] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                    0|MagicMir | [28.08.2022 20:52.33.981] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                    0|MagicMir | [28.08.2022 20:52.34.387] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 20:52 ** ERROR ** null
                                      sdetweil @ally
                                      @ally there is another section of the output…where the error was reported last time
                                      home/pi/.pm2/logs/MagicMirror-error.log
                                      • A
                                        ally @sdetweil
                                        @sdetweil same error
                                        28.08.2022 21:10.34.377] [LOG]   Starting MagicMirror: v2.20.0
                                        [28.08.2022 21:10.34.385] [LOG]   Loading config ...
                                        [28.08.2022 21:10.34.394] [LOG]   Loading module helpers ...
                                        [28.08.2022 21:10.34.399] [LOG]   No helper found for module: alert.
                                        [28.08.2022 21:10.34.419] [LOG]   Initializing new module helper ...
                                        [28.08.2022 21:10.34.420] [LOG]   Module helper loaded: updatenotification
                                        [28.08.2022 21:10.34.422] [LOG]   No helper found for module: clock.
                                        [28.08.2022 21:10.34.635] [LOG]   Initializing new module helper ...
                                        [28.08.2022 21:10.34.638] [LOG]   Module helper loaded: calendar
                                        [28.08.2022 21:10.34.640] [LOG]   No helper found for module: compliments.
                                        [28.08.2022 21:10.34.689] [LOG]   Initializing new module helper ...
                                        [28.08.2022 21:10.34.692] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                                        [28.08.2022 21:10.34.720] [LOG]   Initializing new module helper ...
                                        [28.08.2022 21:10.34.723] [LOG]   Module helper loaded: newsfeed
                                        [28.08.2022 21:10.34.724] [LOG]   All module helpers loaded.
                                        [28.08.2022 21:10.34.833] [LOG]   Starting server on port 8080 ...
                                        [28.08.2022 21:10.34.850] [LOG]   Server started ...
                                        [28.08.2022 21:10.34.853] [LOG]   Connecting socket for: updatenotification
                                        [28.08.2022 21:10.34.855] [LOG]   Starting module helper: updatenotification
                                        [28.08.2022 21:10.34.857] [LOG]   Connecting socket for: calendar
                                        [28.08.2022 21:10.34.859] [LOG]   Starting node helper for: calendar
                                        [28.08.2022 21:10.34.861] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                                        [28.08.2022 21:10.34.863] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                                        [28.08.2022 21:10.34.865] [LOG]   Connecting socket for: newsfeed
                                        [28.08.2022 21:10.34.867] [LOG]   Starting node helper for: newsfeed
                                        [28.08.2022 21:10.34.868] [LOG]   Sockets connected & modules started ...
                                        [28.08.2022 21:10.35.212] [LOG]   Launching application.
                                        [28.08.2022 21:10.38.502] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                        [28.08.2022 21:10.38.552] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                        [28.08.2022 21:10.38.603] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                                        [28.08.2022 21:10.38.642] [INFO]  Checking git for module: default
                                        [28.08.2022 21:10.38.927] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:10.39.643] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:10 ** ERROR ** null
                                        [28.08.2022 21:10.39.896] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:15.39.424] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:15.41.132] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:20.39.237] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:20 ** ERROR ** null
                                        [28.08.2022 21:20.40.820] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:20.42.343] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:25.41.189] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:25.43.553] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:30.39.346] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:30 ** ERROR ** null
                                        [28.08.2022 21:30.41.369] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:30.44.877] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:35.41.533] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:35.46.150] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:40.39.257] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:40 ** ERROR ** null
                                        [28.08.2022 21:40.41.736] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:40.47.660] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:45.41.947] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:45.48.861] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:50.39.355] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:50 ** ERROR ** null
                                        [28.08.2022 21:50.42.128] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:50.50.284] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 21:55.42.480] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 21:55.51.610] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 22:00.39.318] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 22:00 ** ERROR ** null
                                        [28.08.2022 22:00.42.644] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 22:00.52.840] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 22:05.42.822] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                                        [28.08.2022 22:05.54.216] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [28.08.2022 22:10.39.243] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 22:10 ** ERROR ** null
                                          sdetweil @ally
                                          @ally did u add my new code?
                                            bassin12
                                            I’m having some hard time too, I cannot get it to work and get this error, I’m using the same key for the default weather module
                                            [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 07:50 ** ERROR ** Error: Request failed with status code 401
                                            Not sure what I’m doing wrong.
                                            module: “weather”,
                                            position: “top_right”,
                                            header: “Weather Forecast”,
                                            weatherProvider: “openweathermap”,
                                            type: “forecast”,
                                            locationID: “4225309”,
                                            apiKey: “working key”
                                            module: “MMM-OpenWeatherForecast”,
                                            header: “Wettervorschau Schama”,
                                            apikey: “same key as above”, //SUPER SECRET
                                            latitude: 49.039349,
                                            longitude: 11.847070,
                                            units: “metric”,
                                            iconset: “4c”,
                                            colored: true,
                                            concise: true
                                            S 3 Replies Last reply
                                            • 1 / 4
