    MMM-OpenWeatherMapForecast stuck on Loading....
    63 Posts 16 Posters 55.7k Views 18 Watching
    • A
      ally
      I updated my MM with this module and was unable to get it to work, it was just stuck on Loading… so, I tried to revert to the default weather module and same result. Next option was to do a fresh install, so I renamed my MagicMirror folder and installed a clean version and got the default weather module to work with my api key, success. I then reinstalled the OpenWeatherMapForecast module and added the default sample configuration with my api key and it is still stuck on loading, good news is that the default weather module stills works.
      Any suggestions on what I am doing wrong?
      			module: "weather",
      				type: "current",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "XXXXXXX"
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				apiKey: "XXXXXXXXXXXXXXXXXXXX"
      			module: "MMM-OpenWeatherMapForecast",
      			header: "Weather",
      			classes: "default everyone",
      			disabled: false,
      				apikey: "XXXXXXXXXXXXXXXXXXX",
      				latitude: "51.506130",
      				longitude: "-0.090270",
      				iconset: "4c",
      				concise: false,
      				forecastLayout: "table"
      S S L 3 Replies Last reply Reply Quote 0
        sdetweil @ally
        @ally the config.js section you provided is for the built in weather module, in ‘CURRENT’ weather mode
        the openweatherforecast module uses similar config.
        can you open the developers window ctrl-shift-i on the keyboard and select the console tab and scroll up to see any red text
        • A
          ally
          @sdetweil correct. The first too are the default weather modules and the last one is the OpenWeatherMapForecast. I used the sample config provided, I also adjusted as you recommended. I used the default as a test to ensure that the api key etc was working.
          When I am in Chromium and I press ctrl+shift and i see the below red text. Sorry is this what you mean?
          Failed to load resource: net::ERR_FAILED
          app.js:361 ServiceWorker registration succeeded.
          hooks.js:34 [hooks] Changes to hooks on this page …
          hooks.js:28 [hooks] Registered action:ajaxify.end ƒ (){if(!ajaxify.isCold()){d=true}}
          cdn.carbonads.com/carbon.js?serve=CK7IC23N&placement=magicmirrorbuilders:1          Failed to load resource: net::ERR_FAILED
          4main.js:37 Uncaught TypeError: Cannot read properties of undefined (reading 'test')
              at HTMLAnchorElement.u (main.js:37:41)
              at HTMLAnchorElement.handle (jquery.js:5895:29)
              at HTMLBodyElement.dispatch (jquery.js:5430:27)
              at HTMLBodyElement.m.handle (jquery.js:5234:28)
          3main.js:37 Uncaught TypeError: Cannot read properties of undefined (reading 'test')
          DevTools failed to load source map: Could not load content for https://forum.magicmirror.builders/assets/src/modules/pulling-drawer.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          DevTools failed to load source map: Could not load content for https://forum.magicmirror.builders/assets/src/modules/jquery.form.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          Ally
            sdetweil @ally
            @ally ctrl-shift-i on the mm page, not the forums
            • A
              ally @sdetweil
              @sdetweil sorry very new to all of this. I didn’t realise you could do that.
              No issues or red text. It looks like it is working
              main.js:483 Initializing MagicMirror².
              translator.js:128 Loading core translation file: translations/en.json
              translator.js:146 Loading core translation fallback file: translations/en.json
              loader.js:184 Load script: modules/default/alert/alert.js
              module.js:509 Module registered: alert
              loader.js:155 Bootstrapping module: alert
              loader.js:184 Load script: modules/default/alert/notificationFx.js
              loader.js:160 Scripts loaded for: alert
              loader.js:203 Load stylesheet: vendor/css/font-awesome.css
              loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
              loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
              loader.js:162 Styles loaded for: alert
              translator.js:107 alert - Load translation: translations/en.json
              translator.js:107 alert - Load translation fallback: translations/bg.json
              loader.js:164 Translations loaded for: alert
              loader.js:184 Load script: modules/default/updatenotification/updatenotification.js
              module.js:509 Module registered: updatenotification
              loader.js:155 Bootstrapping module: updatenotification
              loader.js:160 Scripts loaded for: updatenotification
              loader.js:203 Load stylesheet: modules/default/updatenotification/updatenotification.css
              loader.js:162 Styles loaded for: updatenotification
              loader.js:164 Translations loaded for: updatenotification
              loader.js:184 Load script: modules/default/clock/clock.js
              module.js:509 Module registered: clock
              loader.js:155 Bootstrapping module: clock
              loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
              loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
              loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
              loader.js:160 Scripts loaded for: clock
              loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
              loader.js:162 Styles loaded for: clock
              loader.js:164 Translations loaded for: clock
              loader.js:184 Load script: modules/default/calendar/calendar.js
              module.js:501 Check MagicMirror² version for module 'calendar' - Minimum version:  2.1.0 - Current version: 2.20.0
              module.js:503 Version is ok!
              module.js:509 Module registered: calendar
              loader.js:155 Bootstrapping module: calendar
              loader.js:244 File already loaded: moment.js
              loader.js:160 Scripts loaded for: calendar
              loader.js:203 Load stylesheet: modules/default/calendar/calendar.css
              loader.js:244 File already loaded: font-awesome.css
              loader.js:162 Styles loaded for: calendar
              loader.js:164 Translations loaded for: calendar
              loader.js:184 Load script: modules/default/compliments/compliments.js
              module.js:509 Module registered: compliments
              loader.js:155 Bootstrapping module: compliments
              loader.js:160 Scripts loaded for: compliments
              loader.js:162 Styles loaded for: compliments
              loader.js:164 Translations loaded for: compliments
              loader.js:184 Load script: modules/default/weather/weather.js
              module.js:509 Module registered: weather
              loader.js:155 Bootstrapping module: weather
              loader.js:184 Load script: modules/default/weather/weatherprovider.js
              loader.js:184 Load script: modules/default/weather/weatherobject.js
              loader.js:244 File already loaded: suncalc.js
              loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
              loader.js:160 Scripts loaded for: weather
              loader.js:203 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
              loader.js:203 Load stylesheet: modules/default/weather/weather.css
              loader.js:162 Styles loaded for: weather
              loader.js:164 Translations loaded for: weather
              loader.js:244 File already loaded: weatherprovider.js
              loader.js:244 File already loaded: weatherobject.js
              loader.js:244 File already loaded: modules/default/weather/providers/openweathermap.js
              loader.js:244 File already loaded: weather-icons.css
              loader.js:244 File already loaded: weather.css
              loader.js:184 Load script: modules/MMM-OpenWeatherMapForecast/MMM-OpenWeatherMapForecast.js
              module.js:501 Check MagicMirror² version for module 'MMM-OpenWeatherMapForecast' - Minimum version:  2.2.0 - Current version: 2.20.0
              module.js:509 Module registered: MMM-OpenWeatherMapForecast
              loader.js:155 Bootstrapping module: MMM-OpenWeatherMapForecast
              loader.js:184 Load script: modules/MMM-OpenWeatherMapForecast/skycons.js
              loader.js:160 Scripts loaded for: MMM-OpenWeatherMapForecast
              loader.js:203 Load stylesheet: modules/MMM-OpenWeatherMapForecast/MMM-OpenWeatherMapForecast.css
              loader.js:162 Styles loaded for: MMM-OpenWeatherMapForecast
              loader.js:164 Translations loaded for: MMM-OpenWeatherMapForecast
              loader.js:184 Load script: modules/default/newsfeed/newsfeed.js
              module.js:509 Module registered: newsfeed
              loader.js:155 Bootstrapping module: newsfeed
              loader.js:160 Scripts loaded for: newsfeed
              loader.js:203 Load stylesheet: modules/default/newsfeed/newsfeed.css
              loader.js:162 Styles loaded for: newsfeed
              loader.js:164 Translations loaded for: newsfeed
              loader.js:203 Load stylesheet: css/custom.css
              alert.js:47 Starting module: alert
              updatenotification.js:18 Starting module: updatenotification
              clock.js:48 Starting module: clock
              calendar.js:87 Starting module: calendar
              compliments.js:38 Starting module: compliments
              weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
              weatherprovider.js:46 Weather provider: OpenWeatherMap started.
              MMM-OpenWeatherMapForecast.js:145 Starting module: MMM-OpenWeatherMapForecast
              newsfeed.js:65 Starting module: newsfeed
              main.js:501 All modules started!
              weather.js:150 New weather information available.
              Ally
                sdetweil @ally
                @ally then we need to look at the pm2 logs more,
                pm2 logs --lines=50
                maybe more 60, ,70, 80…
                • A
                  ally @sdetweil
                  @sdetweil I ran the logs for 80 under the main MagicMirror directory. Hope that is correct way to do it.
                  Below is a sample of the log as I get a spam message when I add it all.
                  home/pi/.pm2/logs/MagicMirror-error.log last 80 lines:
                  0|MagicMir | MESA-LOADER: failed to retrieve device information
                  0|MagicMir | MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                  0|MagicMir | failed to load driver: kms_swrast
                  0|MagicMir | MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                  0|MagicMir | failed to load swrast driver
                  0|MagicMir | [25.08.2022 17:08.13.800] [ERROR] (node:14604) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                  0|MagicMir | [14638:0825/172135.978897:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                  0|MagicMir | X connection to :0 broken (explicit kill or server shutdown).
                  0|MagicMir | [14647:0825/172136.082204:ERROR:command_buffer_proxy_impl.cc(329)] GPU state invalid after WaitForGetOffsetInRange.
                  0|MagicMir | [14604:0825/172136.087957:ERROR:command_buffer_proxy_impl.cc(329)] GPU state invalid after WaitForGetOffsetInRange.
                  0|MagicMir | [25.08.2022 17:22.56.641] [WARN]  You're using a full whitelist configuration to allow for all IPs
                  0|MagicMir | [25.08.2022 17:23.04.450] [ERROR] (node:982) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  0|MagicMir | [1398:0825/172406.366943:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                  0|MagicMir | [1398:0825/172406.367670:ERROR:connection.cc(46)] X connection error received.
                  0|MagicMir | XIO:  fatal IO error 104 (Connection reset by peer) on X server ":0"
                  0|MagicMir |       after 11236 requests (11236 known processed) with 0 events remaining.
                  0|MagicMir | [1412:0825/172413.116477:ERROR:command_buffer_proxy_impl.cc(329)] GPU state invalid after WaitForGetOffsetInRange.
                  0|MagicMir | [982:0825/172413.118265:ERROR:command_buffer_proxy_impl.cc(329)] GPU state invalid after WaitForGetOffsetInRange.
                  0|MagicMir | [25.08.2022 17:25.34.170] [WARN]  You're using a full whitelist configuration to allow for all IPs
                  /home/pi/.pm2/logs/MagicMirror-out.log last 80 lines:
                  0|MagicMir | [26.08.2022 12:20.42.648] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  0|MagicMir | [26.08.2022 12:24.33.069] [LOG]   [MMM-OpenWeatherMapForecast] 26-Aug-22 12:24 ** ERROR ** null
                  0|MagicMir | [26.08.2022 12:24.47.138] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                  0|MagicMir | [26.08.2022 12:25.43.849] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  0|MagicMir | [26.08.2022 12:29.47.307] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                  0|MagicMir | [26.08.2022 12:30.45.025] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  Ally
                    @ally said in MMM-OpenWeatherMapForecast stuck on Loading....:
                    isn’t that helpful!..
                      sdetweil @ally
                      @ally i used your config from
                      https://forum.magicmirror.builders/topic/17141/mmm-openweathermapforecast-stuck-on-loading/1?_=1661513140571
                      with my openweather apikey and it worked without issue.
                        sdetweil @ally
                        @ally edit the node_helper.js of the module and change this
                                            } else {
                                                console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
                        to this
                                            } else {
                                                if(response.statusCode != 200)
                                                console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** bad status ** " + response.statusCode);
                                                    else
                        • A
                          ally @sdetweil
                          @sdetweil any thoughts on why this is occurring on a fresh install of MM and this module? I also just checked the MM change logs and i am definitely running the latest version (## [2.20.0] - 2022-07-02).
                          Ally
                            sdetweil @ally
                            @ally no idea. but without the code change, we won’t know what the error is…
                            only thing I can think of is the apikey has a leading or trailing space, making it bad
                            • A
                              ally @sdetweil
                              @sdetweil yeah, I was worried that might be the case as well, which is why I went to a fresh install and left the original weather module using the same key.
                              Same key, same quotes, no spaces, default settings and this is the result.
                              Config is setup for default weather module current, then forecast and then MMM-OpenWeatherMapForecast, which is stuck on Loading.
                                sdetweil @ally
                                @ally again need the startup messages w the new code
                                I copy/pasted the config u supplied exactly and change to my API key and it worked as expected. so it’s not a config problem.
                                it’s an apikey problem
                                • A
                                  ally @sdetweil
                                  @sdetweil I deleted the old api key and made a new one, same result. The default weather modules load and this one doesn’t.
                                    sdetweil @ally
                                    @ally what is the message from the terminal window w the new code?
                                      stevengill @ally
                                      @ally I removed the location name (e.g. New York) and just used the locationID number and it started to work
                                        sdetweil @stevengill
                                        @stevengill he doesn’t have location specified with the weathermap module
                                          stevengill @sdetweil
                                          @sdetweil sorry, I must have misread this and thought this was their code
                                          • A
                                            ally @sdetweil
                                            @sdetweil This is new.
                                            openweathermap.js:63 Could not load data ...  XMLHttpRequest
                                            (anonymous) @ openweathermap.js:63
                                            openweathermap.js:43 Could not load data ...  XMLHttpRequest
                                            (anonymous) @ openweathermap.js:43
                                            59weather.js:150 New weather information available.
                                            • 1 / 4
