    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 406.4k Views 32 Watching
      MMRIZE @BKeyport
      Append below into your custom.css
      .CX3A {
        width: 300px; /* to test text-wrapping */
      .CX3A .cellBody .fullday .event {
        width: 100%;
      .CX3A .event .startTime::after {
        content: '';
      .CX3A .event .title {
        order: 1;
        width: 180px; /* Adjust for your region width. Here I am using fixed value to make things simple */
        flex-grow: 1;
      .CX3A .event .symbol {
        order: 1;
      .CX3A .event .time.startTime {
        order: 2;
        width: 90px;  /* Adjust for your region width. Here I am using fixed value to make things simple */
        text-align: right;
      .CX3A .event .headline {
        justify-content: space-between;
      • BKeyportB Offline
        BKeyport Module Developer @MMRIZE
        @MMRIZE nearly perfect. Thanks! (I’m tweaking minor things from this)
        • H Offline
          hogedir
          Hi to all !
          I just installed the module MMM-CalendarExt3Agenda which looks like very good but i’m lost in the config file ! i have an error.
          Here is my setup :
          I’ve done 2 tests of config.js:
          TEST1 :
          config.js with
          module: “MMM-CalendarExt3Agenda”,
          position: “top_left”,
          Result : TEST OK, the module is shown.
          TEST2 :
          When I add t config.js
          title: “My Agenda”,
          instanceId: “basicCalendar”,
          locale: ‘de-DE’,
          firstDayOfWeek: 1,
          startDayIndex: -1,
          endDayIndex: 10,
          calendarSet: [‘us_holiday’,],
          /* default/calendar module configuration */
          module: “calendar”,
          broadcastPastEvents: true, // <= IMPORTANT to see past events
          url: “webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics”,
          name: “us_holiday”, // <-- specify calendar name
          color: “skyblue”, // <-- if you don’t want to get color, just remove this line.
          broadcastPastEvents: true, // <-- need to broadcast past events
          maximalNumberOfDays: 30, // <-- how old events would be broadcasted
          maximumEntries: 100, // <-- assign enough number to prevent truncating new events by old events.
          symbol: ‘camera’, // <-- when you want to display simbol. If you don’t want, just set as symbol:[],
          RESULT : error (black screen) and when i do a tail -50 /home/pi/.pm2/logs/MagicMirror-error.log I don’t see nothing special
          Can someone help please?
          M H 2 Replies Last reply Reply Quote 0
            MMRIZE @hogedir
            @hogedir
            I cleaned your config to test.
            • Your quotation mark and double quotation mark seem not standard ASCII code. (It sometimes happens when you copy the codes from Text Editor, which is not for coding.)
            • The last bracket ] for calendars and } of module config seem missing but I think it was just a mistake when you posted the code here.
            Anyway, after cleaning, it works for me.
              module: "MMM-CalendarExt3Agenda",
              position: 'top_left',
              title: 'My Agenda',
                instanceId: 'basicCalendar',
                locale: 'de-DE',
                firstDayOfWeek: 1,
                startDayIndex: -1,
                endDayIndex: 10,
                calendarSet: ['us_holiday'],
              module: 'calendar',
                  url: 'webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics',
                  color: 'skyblue',
                  symbol: 'camera',
              sdetweil @MMRIZE
              @MMRIZE the quotation marks will get mangled if not wrapped in a code block. the forum code treats it as document text
              if u edit it, it’s correct but copy paste from here produces wird type quotes…
              • H Offline
                hogedir @hogedir
                @MMRIZE thank you very much !
                Now i have an issue. I try to connect a FRAMAGENDA calendar to your super module.
                Framagenda is a nextcloud like agenda. So, it needs an authentification (it’s not a direct .ics).
                Here is the config.js with the calendar and MMM-calendarextAgenda module config :
                			url: "https://framagenda.org/remote.php/dav/calendars/calendar_1/test",
                			auth: {
                			    user: 'myuser28632HG4',
                			    pass: 'HDDBG5nSvdjgBVFBVDFFV',
                			    method: 'basic',
                			name: "test", // <-- specify calendar name
                			color: "skyblue", // <-- if you don't want to get color, just remove this line.
                        symbol:[],
                  title: "My Agenda",
                    instanceId: "basicCalendar",
                    locale: 'FR',
                    firstDayOfWeek: 1,
                    startDayIndex: -1,
                		endDayIndex: 10,
                    calendarSet: [''],
                Result : the module works now but there is not Appointment showed, nothing is get from my framagenda calendar.
                Where can i see why it doesn’t dump my calendar ? a log file ?
                  sdetweil @hogedir
                  @hogedir please put your config info in a code block
                  paste
                  select the text you just pasted
                  and pish the button on the top , looks like this
                  • H Offline
                    hogedir
                    I have the connection now after multiple tests to understand the issue.
                    but i think I found a bug in your module @MMRIZE.
                    If I connect to a very simple calendar with 5 appoinments => result : it shows the calendar in the MM without any problem.
                    If i connect to the same calendar but imported with much more information in it (i dumped my other calendar to it which doesn’t work with your module) => it shows NO APPOINTMENT AVAILABLE.
                    It’s possible the french accent we use in france could be the source of the problem, Or too much info in the ics broke the connection?
                    The special caracter like , : ! are ok ? or long sentence ? in the title of the appointment ?
                    other question : what are the others symbols than camera ?
                    How it works to affect the correct symbol to the right appointment? I don’t understand this feature.
                    ==>>Where can i see the log file about your module especially please?
                    thanks a lot
                    • W Offline
                      Wenike @hogedir
                      @hogedir Try setting the max entries for your calendar higher than the default of 100.
                      • BKeyportB Offline
                        BKeyport Module Developer @Wenike
                        @Wenike My max is set to 20, so I doubt that’s the issue. Here’s mine that works great - with events for weeks (because I follow sports)
                        module: "calendar", // Built in
                        //position: "top_right",
                        	broadcastEvents: true,
                        	broadcastPastEvents: false,
                        	fetchInterval: 30000,
                        	maximumEntries: 20,
                        (Calendars follow)
                        (cut)
                        module: "MMM-CalendarExt3Agenda", // https://github.com/MMRIZE/MMM-CalendarExt3Agenda
                        position: "top_center",
                        	showMiniMonthCalendar: false,
                        	firstDayOfWeek: 0,
                        	startDayIndex: 0,
                        	endDayIndex: 99,
                        	minimalDaysOfNewYear: 1,
                        	animationSpeed: 0,
                        	useSymbol: false,
                        	useWeather: false,
                        	waitFetch: 0,
                        	eventTransformer: (ev) => {
                        		if (ev.title.search("⚾") > -1)
                        		ev.title = ev.title.replace("⚾️ ","");
                        		return ev
                        @hogedir - please post your configuration and screenshots like this. You can blur if needed. Alternatively, if you want a daily repeating event for testing, feel free to use my test calendar - I’ll give you the iCal address in private.
                          sdetweil @BKeyport
                          @BKeyport I introduced a bug in 2.20.
                          maximumentries includes those in the past incorrectly
                          you can set it differently for each cal, but if u don’t then the module level value will be used.
                          the bug is fixed in 2.21 coming oct 1.
                          • BKeyportB Offline
                            @sdetweil really? I haven’t noticed. As you can see, I’ve got plenty of events…
                            good to know, though.
                              sdetweil @BKeyport
                              @BKeyport really trouble with past events getting counted
                              • H Offline
                                hogedir
                                I’ve change it from 100 to 100000 and now its works,
                                my calendar is showed now. thanks a lot for your reactivity guys, perfect answer.
                                two other questions : this parameter symbol: ‘camera’ maybe be other value than ‘camera’? I did not understood why camera was by default… is there a list of other symbol values?
                                other question : I want to extend the text limit showing because it’s looks like limited for the events that not have a eaxct duration like 10:00-12:00
                                like you have here in your screen :
                                Thanks.
                                • BKeyportB Offline
                                  BKeyport Module Developer @hogedir
                                  @hogedir The event you point to is generated by the IRS, and is a full day event. the text is theirs.
                                  Here’s my CSS, fully commented for you to borrow:
                                  /* CalendarExt3Agenda */
                                  /* Set CX3a to size, etc. */
                                  .CX3A {
                                  	font-size: 18px;
                                  	min-width: 440px;
                                  	max-width: 440px;
                                  	max-height: 900px;
                                  	overflow-y: unset;
                                  	text-align: left;
                                  	position: relative;
                                  	color: var(--color-text);
                                  	--todayColor: DarkSlateGrey;
                                  	--saturdayColor : orange;
                                  	--sundayColor: darkGoldenRod;
                                  /* Hide useless descriptions, you wanna know, load your calendar */
                                  .CX3A .event .description {
                                  	display: none;
                                  /* Hide useless locations, you wanna know, load your calendar */
                                  .CX3A .event .location {
                                  	display: none;
                                  /* Set up custom full day look */
                                  	color: var(--calendarColor);
                                  	background-color: var(--oppositeColor);
                                  	max-width: 100%;
                                  	padding: 0px 10px;
                                  	width: 100%;
                                  /* make fullday events overflow onto next line */
                                  .CX3A .cellBody .fullday .event .title {
                                  	color: inherit;
                                  	overflow: unset;
                                  	white-space: unset;
                                  	text-overflow: unset;
                                  /* Add the icon to full day events */
                                  .CX3A .cellBody .fullday .event .headline {
                                  	display: inline-block;
                                  /* get rid of the icon for blanks	*/
                                  .CX3A .event .headline .symbol {
                                    display: none;
                                  /* fullday keep the times hidden */
                                  .CX3A .cellBody .fullday .event .headline .time {
                                  	display: none;
                                  /* Start Time Adjustments */
                                  	order: 2;
                                  	width: 90px;
                                  	text-align: right;
                                  /* Stretch title to left justify and organize */
                                  	flex-grow: 1;
                                  /* change date header to center & change color */
                                  .CX3A .agenda .cellHeader {
                                  	justify-content: center;
                                  	color: var(--text-color);
                                  .CX3A .agenda .cellDay {
                                  /* get rid of spare space & dash */
                                  	content: '';
                                  /* Adjust time space */
                                  .CX3A .event .time {
                                  	font-size: unset;
                                  /* Remove End time */
                                  .CX3A .event .endTime {
                                  	display: none;
                                  /* Adjust how tall app is */
                                  .CX3A .agenda {
                                  	position: relative;
                                  	max-height: 900px;
                                  	overflow-y: hidden;
                                  /* Fade adjustments */
                                  .CX3A .agenda::after {
                                  	position: absolute;
                                  	bottom: 0;
                                  	left: 0;
                                  	height: 6%;
                                  	width: 100%;
                                  	content: '';
                                  	background-image: unset;
                                  (shading due to developer console)
                                  I decided to change it up, this is what it looks like now.
                                  color of events is set by the calendar functionality, thusly, background is via CSS:
                                  	url: "http://cal.events/VReW45.ics",
                                  	color: "#002244",
                                  BKeyportB H 2 Replies Last reply Reply Quote 0
                                  • BKeyportB Offline
                                    @MMRIZE said in MMM-CalendarExt3:
                                    Small news.
                                    Now it could get the events from randomBrainstormer/MMM-GoogleCalendar module also.
                                    Are you planning on adding this to Agenda? I could use this.
                                      MMRIZE @BKeyport
                                      @BKeyport already applied.
                                      • H Offline
                                        hogedir @BKeyport
                                        @BKeyport I don’t understand how to extend the full day event like you. mine is limited and i have some space available like that
                                        I want to extend totally the text for fullday event and not having these 3 points “…”
                                        BKeyportB luisestradaL 2 Replies Last reply Reply Quote 0
                                        • BKeyportB Offline
                                          @hogedir It’s documented in my CSS above… Look closely you’ll find it. “fullday events overflow” is a clue.
                                          • W Offline
                                            Wenike @BKeyport
                                            @BKeyport I appreciate you posting your CSS, it gave me a good base to tweak to make my layout work for me (especially getting each event in the calendar’s color but still dimming when that event is in the past.
                                            • 11
                                            • 12
                                            • 2 / 12
