    Multiple screens fo MM.
    36 Posts 13 Posters 28.5k Views 15 Watching
      Mykle1 Project Sponsor Module Developer @tbbear
      @tbbear said in Multiple screens fo MM.:
      OOOO sorryyyy i didnt want a fight
      haha, there’s no fight. Everything is cool. Me, you, ninja, we’re all one happy forum family. :-)
        Mykle1 Project Sponsor Module Developer @Joshrobbs1
        @Joshrobbs1 said in Multiple screens fo MM.:
        My idea is to run two monitors vertical on each side.
        I like the idea a lot. Please keep us posted. i am curious as to whether you experience any performance issues.
        • N Offline
          ninjabreadman @Joshrobbs1
          @Joshrobbs1 Two monitors on each side, or one each/two total? You could run two completely separate mirror instances, or one instance (i.e. server) and hide the modules (via CSS) you don’t want displayed on each one.
          I suggest using a Raspberry Pi Zero W to power one display, run a browser and connect to the other instance/server (or run an MM instance on the RPi Zero W). The server could be on a more powerful Raspberry Pi (3b) or some old laptop hardware. You would want to run the simpler, static modules (weather, time, calendar) on the RPi Zero W and the more demanding, processor-intensive modules (voice, video feeds, complex rendering) on the server.
          I don’t know how MM feels about running two instances on the same machine – you’d need to set different ports, scripts, etc, but I imagine it’s possible with some reconfiguration to avoid collisions.
          • H Offline
            hogedir @ninjabreadman
            @ninjabreadman Hi,
            Now we have a rpi4B with 2 screens available, and i want to display on 2 screens the magic mirror.
            is it possible with the version 2.20 ?
            kayakbabeK S 2 Replies Last reply Reply Quote 0
            • kayakbabeK Offline
              kayakbabe @hogedir
              @hogedir With a raspberry 4 you can have two displays. I’m thinking they can be set up as an extended desktop . Then it’s no big deal with the default magic mirror.
              Top_left and top_right would end up being left and right…
              I haven’t tried this with MM. But I have used my pi with two screens. But in my mind it ought to work with MM.
              Just don’t use the middle_center or any position that would span across both monitors.
              • H Offline
                hogedir @kayakbabe
                @kayakbabe I think we need two electron display, so it’s not quite easy. it’s not just top_left and top_right. I need 2 MMM, 1 magic mirror per screen.
                  sdetweil @hogedir
                  @hogedir electron (and other browsers) runs maximized, which is only one screen…
                  you can DRAG the edge to make the window larger, but cannot maximize over two screens…
                  you can run separate instances of MM on each display…
                  • BKeyportB Offline
                    BKeyport Module Developer @hogedir
                    @hogedir I had two running off one display, just two different Magicmirror installs. I forgot how it works though, was using them as a temporary menu display.
                    Something about calling different config files if I recall right.
                    S K 2 Replies Last reply Reply Quote 0
                      sdetweil @BKeyport
                      @BKeyport MM_CONFIG environment variable
                      allows the different configs off the same directory tree
                      • K Offline
                        karam @BKeyport
                        @BKeyport this answer inspired me to test it, so I have a solution:
                        1. create two different folders.
                        2. configure each install as you like.
                        3. edit each electron file in each folder “js/electron.js”
                        4. change the default resolution and position based on your screens.
                          here is my config:
                        let electronOptionsDefaults = {
                                        width: 1280,
                                        height: 1024,
                                        x: 1366,
                                        y: 0,
                        NOTE: there are many better methods (electron-multi-monitor for example) but this is the easiest that I could find
                          sdetweil @karam
                          @karam u can set the electronOptions in config.js, you don’t need to edit the source file
                          then you can do it with one folder,
                          and two config files
                          MM_CONFIG=config1.js
                          for one
                          and
                          MM_CONFIG=config2.js
                          for the other
                          all modules for both are installed in modules folder, only ones referenced in config file are used
                          installers/mm.sh is the script used by my pm2 setup routine
                          copy that to mm2.sh
                          and then add the export MM_CONFIG=
                          to each
                          then copy the pm2_magicmirror.json
                          and change the title and the mm.sh filename
                          then pm2 start installers/??? (whatever name u copied the json file to for the second mm)
                          pm2 save
                          then on reboot you will get both
                          C S 2 Replies Last reply Reply Quote 1
                            cburchett @sdetweil
                            @sdetweil: can you please share an example? I am not sure how to indicate the secondary display in the config files. Thank you!
                              sdetweil @cburchett
                              @cburchett it’s one big display, so you have to tell it how far from the left edge to start this display.
                              see
                              https://forum.magicmirror.builders/topic/6623/multiple-screens-fo-mm/18?_=1666468889775
                              only need x for horizontal monitors
                              or y for vertical
                                cburchett @sdetweil
                                @sdetweil Perfect! Thank you.
                                  Sagar73594 @sdetweil
                                  @sdetweil said in Multiple screens fo MM.:
                                  Can you please elaborate, a little bit more? I’m trying this, but not understood well.
                                  Thank You.
                                    sdetweil @Sagar73594
                                    @Sagar73594 if you have a bash or sh script, you can set environment variables that the MM code will read
                                    export MM_CONFIG=??? filename
                                    will cause filename to be used as the name of the file to read for configuration (replacing config.js)
                                    if you use my install script and selected use pm2, then the script is
                                    ~/MagicMirror/installers/mm.sh
                                    before the line
                                    npm start
                                    add the line above to set the file name
                                    so, by using different config files, one could launch multiple instances of MagicMirror from the same set of files.
                                    some could target one display and others another, and some could be server only as weill.
                                    one could also install 50 modules and use the same 25 in all instances and some mix of the others in different instances, all from the same set of files in the MagicMirror folder tree.
                                    C 2 Replies Last reply Reply Quote 0
                                      chichi1887 @sdetweil
                                      before the line
                                      npm start
                                        before the line
                                        npm start
                                        Hi Sagar,
                                        Hello Sagar, thank you for your guidance. Unfortunately, I keep encountering an error upon startup. A version starts automatically with the familiar error message “npm run config: check”. I stop the MagicMirror and manually start it from the MagicMirror folder with npm start, but then it allegedly cannot find the config. As you described, I created config1 and config2, then edited installers/mm.sh and mm2.sh. It looks something like this now:
                                        export MM_CONFIG=config2.js
                                        DISPLAY=:2 npm start
                                        I also copied the pm2_MagicMirros.json once and simply appended a “1” to the name. The configuration looks like this:
                                        “apps” : [{
                                        “name” : “MagicMirror”,
                                        “script” : “/home/pi/MagicMirror/installers/mm.sh”,
                                        “watch” : [“/home/pi/MagicMirror/config/config1.js”]
                                        Do you perhaps have any tips for me on what I might be doing wrong?
                                          sdetweil @chichi1887
                                          @chichi1887 well, you need two pm2_MagcMirror.json, right? and each points to a different mm.sh, right?
                                          original
                                          pm2_MagicMirror.json
                                          "apps" : [{
                                          "name" : "MM_Screen1",
                                          "script" : "/home/pi/MagicMirror/installers/mm.sh",
                                          "watch" : ["/home/pi/MagicMirror/config/config.js"]
                                          new pm2_MagicMirror2.json
                                          "apps" : [{
                                          "name" : "MM_Screen2",
                                          "script" : "/home/pi/MagicMirror/installers/mm2.sh",
                                          "watch" : ["/home/pi/MagicMirror/config/config2.js"]
                                          then
                                          pm2 start each json
                                          and then pm2 save
                                          to test before pm2 start , you can
                                          installers/mm2.sh
                                          or
                                          installers/mm.sh
                                          to start them both, open another terminal window or ssh session, starting one in each
                                          ctrl-c in the term window will end that instance
                                            installers/mm2.sh
                                            Hey,
                                            the mm.sh starts without a problem but the second has this
                                            all modules that starts on the mm.sh are disable in the mm2 config.
                                            Display=0 in both are correkt or the second must be nr.1?
