This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
PIR sensor to turn on LED strip
@Egnos Hi, as the picture says they use the 5V power source of the led strip to power the Pi, too.
Instead of powering the pi via USB they use the 5V GPIO pin.
If you want to power the Pi via USB instead be sure to connect the Ground of the strip with ground of the pi. -
@Egnos no. they are powering the pi from the 5v gpio pins as well as the LEDs.
the pin is tall.
@wishmaster270 said in PIR sensor to turn on LED strip:
The GPIO ground or the power ground going into USB-C?
thanks
@Egnos gpio
@sdetweil thanks
