    MMM-NewsFeed multiple instances
    12 Posts 3 Posters 1.9k Views 3 Watching
    • E Offline
      Egnos
      I realized that the two instances overlap, regardless of the position given in the configuration.
      both modules work (MMM-NewsFeed and MMM-NewsFeed2) but “cover” each other …
        sdetweil @Egnos
        @Egnos then you would have to have to fiddle with CSS
        so would have to rename the css file and change the response to getStyles to the new name…
        THEN you could use custom.css to attempt to fix
        as I said, you could ‘try’ the rename approach… sometimes not so easy…
        • E Offline
          Egnos @sdetweil
          @sdetweil said in MMM-NewsFeed multiple instances:
          Below the “MMM-NewsFeed2.css” file contained in the module but I can’t find "getStyles ":
          /* Magic Mirror
           * Module: NewsFeed
           * By @bugsounet -- Dupont Cédric <bugsounet@bugsounet.fr>
           * MIT Licensed.
          #NEWSFEED_CONTENER {
            line-height:1.1em;
            width: 100%;
          #NEWSFEED_CONTENER.showArticle {
            opacity: 1;
            transition: opacity 1s linear;
          #NEWSFEED_CONTENER.hideArticle {
            opacity: 0;
          #NEWSFEED_TITLE {
            margin-left: auto;
            margin-right: auto;
            white-space: nowrap;
            overflow: hidden;
            text-overflow: ellipsis;
          #NEWSFEED_ARTICLE {
            font-size: 90%;
            display: flex;
          #NEWSFEED_CONTENT {
            padding: 10px;
            margin-top: 1px;
            font-size: 70%;
            text-align: left;
            height: 80px;
            display: flex;
          #NEWSFEED_IMAGE {
            margin-right: 10px;
            float: left;
            max-width: 10vw;
            max-height: 10vh;
            text-align: left;
          #NEWSFEED_DESCRIPTION {
            opacity: 0;
            line-height: 25px;
            text-align: justify;
            overflow: hidden;
            display: -webkit-box;
            -webkit-line-clamp: 3;
            -webkit-box-orient: vertical;
          #NEWSFEED_DESCRIPTION.showArticle {
            animation: 3s ease 0s normal forwards 1 fadein;
          @keyframes fadein{
            0%   { opacity:0; }
            66%  { opacity:0; }
            100% { opacity:1; }
          #NEWSFEED_DESCRIPTION.hideArticle {
            opacity: 1;
            animation: none;
          #NEWSFEED_FOOTER {
            text-align:right;
          #NEWSFEED_LOGO {
            font-size: 100%;
            font-weight: bold;
            display: flex;
          #NEWSFEED_LOGO_PARTA {
            margin-left: 10px;
          #NEWSFEED_LOGO_PARTB {
            margin-right: 10px;
          #NEWSFEED_SOURCE {
            margin-right: 8px;
            font-weight: bold;
            margin-top: -9px;
            margin-bottom: 5px;
            text-align: left;
          #NEWSFEED_SOURCE.start {
            animation-duration: .8s;
            animation-name: clignoter;
            animation-iteration-count: 2;
            transition: none;
            animation-delay: 1s;
          #NEWSFEED_SOURCE.stop {
            animation-name: stopclignoter;
            animation-iteration-count: 1;
          @keyframes clignoter {
            0%   { opacity:1; }
            40%  { opacity:0; }
            100% { opacity:1; }
          @keyframes stopclignoter {
            0%   { opacity:1; }
          #NEWSFEED_TIME {
            font-size: 50%;
            text-align: right;
            display: inline-block;
            margin-right: 10px;
            margin-top: 10px;
            margin-bottom: -5px;
          #NEWSFEED_INFO {
            width: 100%;
            height: 110px;
          #NEWSFEED_QRCODE {
            height: 120px;
            width: 120px;
            margin-top: 0px;
            margin-right: -10px;
            margin-left: 5px;
          /** Vertical **/
          #NEWSFEED_TITLE.vertical {
            display: none;
          #NEWSFEED_CONTENT.vertical {
            font-size: 80%;
          #NEWSFEED_IMAGE.vertical {
            float: unset;
            display: block;
            margin-left: auto;
            margin-right: auto;
            max-width: 20vw;
            max-height: 20vh;
          #NEWSFEED_SOURCE.vertical {
            text-align: center;
            margin-top: auto;
            margin-bottom: auto;
            line-height: 22px;
          #NEWSFEED_QRCODE.vertical {
            height: 100px;
            width: 100px;
            min-width: 100px;
            min-height: 100px;
            /* display: inline-block; */
            margin-right: 0px;
            margin-top: 3px;
            margin-left: 0px;
          #NEWSFEED_CONTENER_TITLE {
            display: flex;
          #NEWSFEED_DESCRIPTION.vertical {
            line-height: 20px;
            margin-top: 5px;
            -webkit-line-clamp: 10;
          #NEWSFEED_TIME.vertical {
            font-size: 60%;
            margin-top: 0px;
          A S 2 Replies Last reply Reply Quote 0
            Anthony Project Sponsor @Egnos
            @Egnos Why don’t you try different modules?
            • E Offline
              Egnos @Anthony
              @Anthony said in MMM-NewsFeed multiple instances:
              Hi @Anthony, I have not found any RSS Feed modules that show the image of the article.
              Do you have something to advise me?
              Thanks.
                sdetweil @Egnos
                @Egnos getStyles is in the MMM-Newfeed2.js
                  @Egnos I didn’t know you want a picture too. Although this, this and this seem to have a picture of the article but better is to check them yourself to see if they fit your needs.
                  • E Offline
                    Egnos @sdetweil
                    yes yes, I already did. I tried to move it with the “custom.css” but I could not move it (probably due to my lack of knowledge of css …).
                    Can you recommend a few lines of CSS code to move MMM-Newsfeed2?
                    Now I take a look at it, I typically avoid modules with API to get from registration. But if it’s the only solution …
                    Thank you all
                      sdetweil @Egnos
                      @Egnos sorry, this one looks more difficult to move around
