    v2.21.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 4.2k Views 1 Watching
    • MichMichM Offline
      MichMich
      [2.21.0] - 2022-10-01
      https://github.com/MichMich/MagicMirror/releases/tag/v2.21.0
      Special thanks to: @BKeyport, @buxxi, @davide125, @khassel, @kolbyjack, @krukle, @MikeBishop, @rejas, @sdetweil, @SkySails and @veeck
      Added
      • Possibility to fetch calendars through socket notifications.
      • New scripts install-mm (and install-mm:dev) for simplifying mm installation (now: npm run install-mm) and adding params --no-audit --no-fund --no-update-notifier for less noise.
      • New showTimeToday option in calendar module shows time for current-day events even if timeFormat is "relative".
      • Add hourly forecasts, apparent temperature & custom location name to SMHI weather provider.
      Removed
      • Old weather deprecated modules currentweather and weatherforecast.
      Updated
      • Removed DAYAFTERTOMORROW from English.
      • Update dependencies.
      • Updated jsdoc.
      • Updated font tree to use variables consistantly.
      • Removed deprecated Docker Repository from issue template.
      Fixed
      • Broadcast all calendar events while still honoring global and per-calendar maximumEntries.
      • Respect rss ttl provided by newsfeed (#2883).
      • Fix multi day calendar events always presented as “(1/X)” instead of the amount of days the event has progressed.
      • Fix weatherbit provider to use type config value instead of endpoint.
      • Fix calendar events which DO NOT specify rrule byday adjusted incorrectly (#2885).
      • Fix e2e tests not failing on errors (#2911).
      • MichMichM MichMich locked this topic on
