upgrade to new NPM version?
11 Posts 4 Posters 3.2k Views 4 Watching
  • K Offline
    kai
    Hi there,
    thank you all very much for looking after the MM and keeping it alive and developing it further.
    The update to version 2.21.0 was successful, no problems, everything is fine! :thumbs_up:
    I only have one question: I got a hint saying that there is a new NPM version. Can I stay on my current version 6.14.12 or should I upgrade to 8.19.2?
    Thank you very much!
    May the code be with you
    -kai
    S 1 Reply Last reply Oct 2, 2022, 3:49 PM Reply Quote 0
      sdetweil @kai
      @kai don’t worry about that … we do not depend on NPM v8
      K 1 Reply Last reply Oct 2, 2022, 4:34 PM Reply Quote 0
      • K Offline
        kai @sdetweil
        @sdetweil cool, thanks a lot!
        K 1 Reply Last reply Oct 9, 2022, 12:09 PM Reply Quote 0
        • K Offline
          KristjanESPERANTO Module Developer @kai
          Since 6.14.12 there have been a lot of bug fixes, so an upgrade is recommended. And MM works fine with 8.19.2.
          S 1 Reply Last reply Oct 9, 2022, 12:14 PM Reply Quote 1
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO if they are running fine, no reason to upgrade. when a new mm release comes that needs a new node or npm, then my script will upgrade that too
            E 1 Reply Last reply Oct 27, 2022, 8:33 PM Reply Quote 0
            • E Offline
              eltonnascimento @sdetweil
              @sdetweil how to update npm version?my MM is on the last version, but my raspian already has a better version of npm than my Magic mirror, but my MM doesnt see that.
              S 1 Reply Last reply Oct 27, 2022, 9:36 PM Reply Quote 0
                sdetweil @eltonnascimento
                @eltonnascimento sudo npm i npm@version-numnumber
                note that I may have to npm install in every module folder that has a package.json and the base
                I would ignore the message.
                my upgrade script will be upgraded to install npm 8 on the next release (jan, 1)
                E 1 Reply Last reply Oct 28, 2022, 11:27 AM Reply Quote 0
                • E Offline
                  @sdetweil I ran the command sudo npm i npm@8.19 inside the /MagicMirror folder, but it didn’t update the npm version. then I ran the command npm install inside MMM-Tools, without success.
                  Ashampoo_Snap_sexta-feira, 28 de outubro de 2022_08h26m03s_003_.png Ashampoo_Snap_sexta-feira, 28 de outubro de 2022_08h24m40s_002_.png
                  do you have any other tips?
                  S 1 Reply Last reply Oct 28, 2022, 1:04 PM Reply Quote 0
                    @eltonnascimento but it did. npm is 8 now
                    E 1 Reply Last reply Oct 28, 2022, 3:48 PM Reply Quote 0
                    • E Offline
                      @sdetweil but the MM-Tools module, indicates that npm is v6.14.12…as in the first picture above. I already did the npm install inside the MMM-Tools directory as well.
                      S 1 Reply Last reply Oct 28, 2022, 4:12 PM Reply Quote 0
