    Electron Install Error - Electron not found
    18 Posts 3 Posters 4.8k Views 3 Watching
      CLLA1972
      Hi!
      Just did a MM-upgrade and after that I have problems to get MM started. I attach the error messages.
        sdetweil @CLLA1972
        @CLLA1972 I don’t know
        make a backup
        see my https://github.com/sdetweil/MagicMirror-backup-restore
        then rename the MagicMirror folder out of the way, and run my install script. see if we can get running
        see
        if so, then run the restore to put back all the modules and config in the new mm folder created by install
          sdetweil @CLLA1972
          @CLLA1972 yes, looks like another fun npm install problem
          do
          sudo rm -rf node_modules
          rm package-lock.json
          npm install --omit=dev
            CLLA1972 @sdetweil
            @sdetweil Thanks so much for the support. Still not “there yet”. I got the following error message. Image.JPG
            Again, THANKS !!!
              sdetweil @CLLA1972
              @CLLA1972 can u do
              uname -a
              is this a pi0?
              C 2 Replies Last reply Reply Quote 0
                CLLA1972 @sdetweil
                @sdetweil Hi. I am using a PI3B+ /Thanks.
                  sdetweil @CLLA1972
                  @CLLA1972
                  ok, troublesome
                  rm -rf node_modules/electron
                  npm install electron@19.0.15
                    CLLA1972 @sdetweil
                      CLLA1972 @sdetweil
                      @sdetweil Here the result.
                        sdetweil @CLLA1972
                        @CLLA1972
                        show output of node -v
                        run my upgrade script with force instead of apply (as u are on the latest release)
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                          sdetweil @CLLA1972
                          @CLLA1972 ok, I don’t get what is going on, but
                          rm -rf node_modules/env-paths
