    Electron Install Error - Electron not found
    18 Posts 3 Posters 5.2k Views 3 Watching
      CLLA1972
      Hi!
      Just did a MM-upgrade and after that I have problems to get MM started. I attach the error messages.
        sdetweil @CLLA1972
        @CLLA1972 I don’t know
        make a backup
        see my https://github.com/sdetweil/MagicMirror-backup-restore
        then rename the MagicMirror folder out of the way, and run my install script. see if we can get running
        see
        if so, then run the restore to put back all the modules and config in the new mm folder created by install
          sdetweil @CLLA1972
          @CLLA1972 yes, looks like another fun npm install problem
          do
          sudo rm -rf node_modules
          rm package-lock.json
          npm install --omit=dev
            CLLA1972 @sdetweil
            @sdetweil Thanks so much for the support. Still not “there yet”. I got the following error message. Image.JPG
            Again, THANKS !!!
              sdetweil @CLLA1972
              @CLLA1972 can u do
              uname -a
              is this a pi0?
              C 2 Replies Last reply Reply Quote 0
                CLLA1972 @sdetweil
                @sdetweil Hi. I am using a PI3B+ /Thanks.
                  sdetweil @CLLA1972
                  @CLLA1972
                  ok, troublesome
                  rm -rf node_modules/electron
                  npm install electron@19.0.15
                    CLLA1972 @sdetweil
                      CLLA1972 @sdetweil
                      @sdetweil Here the result.
                        sdetweil @CLLA1972
                        @CLLA1972
                        show output of node -v
                        run my upgrade script with force instead of apply (as u are on the latest release)
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                          sdetweil @CLLA1972
                          @CLLA1972 ok, I don’t get what is going on, but
                          rm -rf node_modules/env-paths
                            CLLA1972 @sdetweil
                            @sdetweil Hi again. First of all, thanks for the great help. I am really in deep water here and I really do not want to reboot the whole PI and start from scratch. Here the result from the latest command and the log file. Again THANKS !!AA.JPG [2022-10-17T20_15_34_187Z-debug-0.log](Invalid file type. Allowed types are: .jpg, .jpeg, .png, .gif, .png, .jpg, .jpeg, .gif)
                            C S 2 Replies Last reply Reply Quote 0
                              CLLA1972 @CLLA1972
                              @CLLA1972 574 timing build:link:node_modules/read-pkg/node_modules/semver Completed in 65ms
                              575 timing build:link Completed in 83ms
                              576 info run playwright@1.26.1 install node_modules/playwright node install.js
                              577 info run playwright@1.26.1 install { code: 1, signal: null }
                              578 timing reify:rollback:createSparse Completed in 3063ms
                              579 timing reify:rollback:retireShallow Completed in 5ms
                              580 timing command:install Completed in 329571ms
                              581 verbose stack Error: command failed
                              581 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                              581 verbose stack at ChildProcess.emit (node:events:527:28)
                              581 verbose stack at maybeClose (node:internal/child_process:1092:16)
                              581 verbose stack at Socket. (node:internal/child_process:451:11)
                              581 verbose stack at Socket.emit (node:events:527:28)
                              581 verbose stack at Pipe. (node:net:709:12)
                              582 verbose pkgid playwright@1.26.1
                              583 verbose cwd /home/pi/MagicMirror
                              584 verbose Linux 5.15.32-v7+
                              585 verbose node v16.16.0
                              586 verbose npm v8.11.0
                              587 error code 1
                              588 error path /home/pi/MagicMirror/node_modules/playwright
                              589 error command failed
                              590 error command sh -c node install.js
                              591 error BEWARE: your OS is not officially supported by Playwright; downloading fallback build.
                              591 error Downloading Chromium 106.0.5249.30 (playwright build v1024)…
                              591 error | | 0% of 135.1 Mb
                              592 error /home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:709
                              592 error throw new Error(Failed to download ${title}, caused by\n${e.stack});
                              592 error ^
                              592 error
                              592 error Error: Failed to download Chromium 106.0.5249.30 (playwright build v1024), caused by
                              592 error Error: getaddrinfo EAI_AGAIN playwright-verizon.azureedge.net
                              592 error at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:71:26)
                              592 error at /home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:709:13
                              592 error at async Registry._downloadExecutable (/home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:708:5)
                              592 error at async Registry.install (/home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:672:9)
                              592 error at async installBrowsersForNpmInstall (/home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:876:3)
                              593 verbose exit 1
                              594 timing npm Completed in 330071ms
                              595 verbose unfinished npm timer reify 1666037734674
                              596 verbose unfinished npm timer reify:build 1666037983317
                              597 verbose unfinished npm timer build 1666037983330
                              598 verbose unfinished npm timer build:deps 1666037983332
                              599 verbose unfinished npm timer build:run:install 1666037983509
                              600 verbose unfinished npm timer build:run:install:node_modules/playwright 1666037983511
                              601 verbose code 1
                              602 error A complete log of this run can be found in:
                              602 error /home/pi/.npm/_logs/2022-10-17T20_15_34_187Z-debug-0.log
                                sdetweil @CLLA1972
                                @CLLA1972
                                repeat the last message instructions but change the npm install to
                                npm install electron@19.0.15 --omit=dev
                                • karsten13K Offline
                                  karsten13 @sdetweil
                                  there is a typo in rm -rf nodel_modules/env-paths …
                                    sdetweil @karsten13
                                    @karsten13 dang phones
                                      CLLA1972 @sdetweil
                                      @sdetweil Did now the commande without the Typo :flushed_face: and god this one (similar to a previous one) . I am getting close to the solution?AA.JPG :-)
                                        sdetweil @CLLA1972
                                        make a backup
                                        see
                                          CLLA1972 @sdetweil
                                          @sdetweil Thanks! Great! That got me back on track again !!! THANKS !!! :clapping_hands_medium-light_skin_tone: :folded_hands:
