    MMM-CalendarExt2
    486 Posts 83 Posters 937.9k Views 83 Watching
      sdetweil @nschertz
      @nschertz I don’t know, but you can learn the css settings by using the developers window
      see
      https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1650761970911
      • N Offline
        nschertz @sdetweil
        @sdetweil Thanks. That redirect was very helpful. Problem solved.
        • H Offline
          hrmax23
          I’ve added a border around today’s date in the month view but I can’t seem to figure out how to adjust the actual events to not overlap the left border. Anyone know how to do this?
          • F Offline
            fedale
            How do i get an extra colium for week numbers? Today its in the field for monday in my calendar.How do i specify this in css?
            I have the weeksmark added. But unsure how to resolve this into its own colum. Any one have a surgestion?
              sdetweil @fedale
              @fedale use MMM-CalendarExt3.
              ext2 is no longer supported
              • F Offline
                fedale @sdetweil
                @sdetweil okay thanks. I did not know that.
                  justbob
                  How can I make the calendar show more than two lines of text for each event?
                  I’ve had start and end times set up, but that would leave room for a few letters and it would look like:
                  ‘08:00-09:30 Ext…’
                  Then I’ve used this:
                  .CX2 .weekSlot .event:not(.fullday) .eventMain {
                  height: auto;
                  flex-wrap: wrap;
                  flex-grow: 0;
                  overflow: visible;
                  and it allowed me to have time in one row, and text in another, however if the text alone is more than what could be fit in a single row, again I get 3 dots instead of having the box adjust to the size of the text.
                  It would look like this:
                  ‘08:00-09:30
                  Extended line of t…’
                  Also, whenever I have two enlarged boxes in the same day, the second one would partially go over the previous one, as if the previous one wasn’t enlarged.
                  Any ideas how I could solve these two issues?
                  BKeyportB M 2 Replies Last reply Reply Quote 0
                  • BKeyportB Offline
                    BKeyport Module Developer @justbob
                    @justbob I’d switch to CX3agenda, to be honest. Much better.
                      MMRIZE @justbob
                      @justbob
                      That module doesn’t be designed like that. Of course, a heavy tweak of CSS could be the solution, but not recommended.
                      First, unpretty.
                      Second, The purpose of the module is to glance at outlines at once. Multi lines are not so easy to scan. I recommend transforming the title abbreviately or using color/symbol to distinguish the points rapidly.
                      Third, technically not so easy to align the event cells with different lines(heights) in the same row. To accomplish it, that will inevitably waste space. So I haven’t designed so.
                        justbob
                        @MMRIZE @BKeyport
                        I prefer functionality over looks, and CX3agenda doesn’t satisfy my wants and needs.
                        I want a calendar which shows a month and a half in advance, and which shows all the events in a single calendar. Having those in a list is both harder for me to follow-up on and find the gaps.
                        I’ve given a thought to CalendarExt3, and while I like the idea behind it (to make it more simple for regular Joe, as Ext2 “is too complicated”), I’ve got a feeling that it has less features and because of it’s simplicity lacks all the customization options that Ext2 has. Am I right?
                        As for space wasted, I assume you meant that if one day has, lets say 5 events, and other none, there would basically be a lot of space unused (as in, a lot of empty squares being “empty”, but taking the space anyway)? If so, I really don’t care about that, rather, I prefer it that way.
                        I don’t want to just glance at it, I want it to be as informative as possible, to help me build my future schedules and plan events. Some events simply need explanation, because one word or shorting that one word won’t cut it.
                        So, with all that said, does anyone knows of a way to make it work as I imagined?
                        • 45
                        • 46
                        • 47
                        • 48
                        • 49
                        • 47 / 49
