    [MMM-TouchButton] A module to add clickable buttons to send notifications or run commands
    7 Posts 4 Posters 6.0k Views 4 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer
      Description:
      If you control your mirror by mouse or with a touch panel and want to add buttons to send notifications or run commands this is your module.
      The module can be added at different locations with different configurations and supports to change the classes and/or change the icons based on the output/return code of the called commands since version 0.0.2.
      Screenshots:
      Download:
      Download
      [card:Tom-Hirschberger/MMM-TouchButton]
      Version 0.0.9
      • bumped version of jsonpath-plus library to 10.1.0
      Version 0.0.8
      Version 0.0.7
      • bumped jsonpath-plus library to version 10.0.1
      Version 0.0.6
      • classes now will be added to the title element, too
      • fixed string handling in conditions
      • it is possible to send notifications without payload now
      Version 0.0.5
      • fixed not running actions of Iconify icons
      • added support to validate the payload of notifications as condition
      • added support to parse the value of conditions with jsonpath-plus
      Version 0.0.4
      • added support of Iconify icons
      Version 0.0.3
      • fixed a bug which caused a black screen if no additional classes had been set
      • prefixed all CSS configuration with the modules main class
      Version 0.0.2
      • configure multiple instances of the module at different positions with different configuration
      • add additional classes to the elements
      • hide/show buttons based on the current active profile
      • change the icon or/and classes the the buttons based on the output and/or return code of the called commands
      Version 0.0.1
      • Add as much buttons as you like. Each with a unique css class and an Font Awesome (The build in version of MagicMirror, currently 4.7) icon assigned.
      • If a button gets pressed either a command (with arguments) can be executed on the command line or an notification (with payload) can be send.
        Sierra0815
        Thank you very much for this module.
        These buttons finally behave like expected. I already tested MMM-Smarttouch and MMM-OnScreenMenu but never got it working in satisfying way with my infrared frame.
        Grüße aus Stuttgart
        wishmaster270W 1 Reply Last reply Reply Quote 1
          wishmaster270 Module Developer @Sierra0815
          @Sierra0815 Great to hear that. I developed the module a view years ago to provide buttons to toggle some modules (like snowfall) and to realize user presence notifications via remote connection.
            BreanneDolphin
            @wishmaster270 I am fairly new to MagicMirror, I have a touch screen without a keyboard, but I am unsure how to set the button up for it just to exit the MagicMirror and not reboot the whole thing? Could you help?
              sdetweil @BreanneDolphin
              @BreanneDolphin how is MagicMirror started?
              npm start
              send a ctrl-q
              to the MM UI
              or pm2 on boot
              pm2’s JOB is to keep the app running… if it ends, pm2 will restart it…
              so then you will have to issue a command
              pm2 stop x
              where x is the name or number on the line for the app you want to stop
              from the output of
              pm2 status
              like this
              │ id │ name                │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
              │ 1  │ MagicMirror         │ default     │ 2.15.0  │ fork    │ N/A      │ 0      │ 27   │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
              │ 7  │ MagicMirror1        │ default     │ 2.26.0  │ fork    │ 0        │ 0      │ 9    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
              │ 2  │ startspot           │ default     │ N/A     │ fork    │ 7510     │ 20D    │ 418  │ online    │ 0%       │ 2.0mb    │ sam      │ disabled │
              so on line id =1 or name = MagicMirror
                BreanneDolphin @sdetweil
                @sdetweil it’s just started with npm start
                  @BreanneDolphin so, then you have to run a command that can send a keystrokes to mm.
                  see xdotool
