    Using MMM-Widget for images
    13 Posts 3 Posters 4.7k Views 3 Watching
    • N6NGN Offline
      N6NG @wishmaster270
      @wishmaster270 Thank you… I’ll give it a try…
      Dennis
      N6NGN 1 Reply Last reply Reply Quote 0
      • N6NGN Offline
        N6NG @N6NG
        @N6NG
        I put this in my config.js and I get nothing in the bottom_right of my screen. The rest of my MM looks fine… but nothing shows up
        from this module.
        module: “MMM-MMM-EmbedURL”,
        position: “bottom_right”,
        header: “Embed-URL”,
        updateInterval: 120,
        embedElementType: “img”,
        embed: [
        “https://www.hamqsl.com/solarmuf.php”
        Dennis
        • wishmaster270W Offline
          wishmaster270 Module Developer @N6NG
          @N6NG
          Sorry, there was a copy paste mistake in the example. The module name was wrong…
            module: "MMM-EmbedURL",
            position: "top_center",
            header: "Embed-URL",
              embedElementType: "img",
              embed: [
                  "https://www.hamqsl.com/solarmuf.php"
          N6NGN 2 Replies Last reply Reply Quote 0
          • N6NGN Offline
            N6NG @wishmaster270
            @wishmaster270 I couldn’t see how that would affect it but it sure did…
            Thank you so much… works fine lasts a long time.
            Dennis N6NG
              sdetweil @N6NG
              @N6NG MagicMirror uses the module: setting to find the folder and files…
              currently a mispelling is not reported
              • N6NGN Offline
                N6NG @sdetweil
                @sdetweil That makes sense… It works well now.
                • N6NGN Offline
                  N6NG @wishmaster270
                  @wishmaster270 Is their any way to size the img?
                  Dennis
                    @N6NG I put a small section about styling to the readme.
                    It is done via custom.css
                    .embed .embeded {
                        width: 800px;
                        height: 400px;
                      sdetweil @wishmaster270
                      @wishmaster270 you should always include your module name 1st, in case some other module uses the same sub classes
                        wishmaster270 Module Developer @sdetweil
                        @sdetweil Hi Sam, your right. Did avoid this in the past because it was a problem if someone copied the module to have multiple instances. As most of my modules provide multi instance now this shouldn’t be a problem anymore.
                        I will check the css files of my modules and add prefix all CSS with MMM-ModuleName.
                          @wishmaster270 and one can make use of the module classes property to make unique names for each of the instances so that you could Target the CSS to the appropriate instance
                          but like copying, the css must be updated w the new class name selector
