    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 222.3k Views 28 Watching
      Alvinger @Zapman
      @Zapman said in MMM-ResRobot - Public transport information for Sweden:
      			module: "MMM-ResRobot",
                              header: "Departures",
                                      routes: [ // stations from:
                                              {from: "740015972", to: ""},
                                      apiKey: "API-KEY-HERE"
      @Zapman You can’t have a comment in the middle of the config. Remove the " // stations from: " and it should work.
      This is what it looks like for me:
        sdetweil @Alvinger
        @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
        sure you can, they are ignored, there are comments all over the place
          Alvinger @sdetweil
          @sdetweil Yes, they should be. However, when I pasted @Zapman’s config into my test site, it didn’t work. When I removed the comment it worked. Go figure!
          Z S 2 Replies Last reply Reply Quote 0
          • Z Offline
            Zapman @Alvinger
            @Alvinger Everything is working great now! Thank you for the fast response to my issue! I’ll use this module a lot from now on :smiling_face_with_open_mouth:
              sdetweil @Alvinger
              @Alvinger i added that config to another module with the comment and got what was expected. 1 route structure in an array
                Alvinger @sdetweil
                @sdetweil Really strange. You got the expected behavior but @Zapman and I got it to work when we removed the comment. I should state that I use a fork of MM as my screens are iPad 4 running IOS9.3.5 which might have an impact. But I don’t know which MM @Zapman uses.
                  Alvinger @Zapman
                  @Zapman You’re welcome. Do let me know if you see anything you want to add/change.
                    SvenT @Alvinger
                    @Alvinger Thank You for a brilliant module that works like a charm.
                    Do You have a simple fix for limiting updates?
                    I want frequent updates for my bus stop when present, and none when I’m not present…
                    I have a PIR sensor hooked up. Possible to use that? Suspend module?
                    OR a simple schedule as proposed by Trafiklab:
                    https://www.trafiklab.se/docs/using-trafiklab-data/best-practices/limiting-requests/
                    Not a high prio request…
                    Cheers
                    /Sven
                    S A 2 Replies Last reply Reply Quote 0
                      sdetweil @SvenT
                      @SvenT I would post an issue to the module GitHub issues page to engage the author
                        Alvinger @SvenT
                        @SvenT I have experimented with a number of algorithms for minimizing updates but ended up with the one implemented. The current algorithm is:
                        • If initial request, get updates from Trafiklab
                        • If the first item in departure list (per routeId) is “old”, i.e. before cutoff time (now + skipMinutes), clear list (for routeId) and get updates from Trafiklab
                        What the above means is that updates only occur ON ACTUAL DEPARTURES, e.g. if a bus departs every 15 minutes the module will get updates from Trafiklab every 15 minutes (per routeId). In rush hour this often means that the module get updates every minute but at night it might only update once per 60 minutes or longer (per routeId). This behavior has the benefit of automatically adjusting to rush hour and slow hours without user intervention or tweaking.
                        If only one routeId is configured, the number of Trafiklab updates is usually way below the Trafiklab suggestions.
                        /j
                          SvenT @Alvinger
                          @Alvinger I see.
                          My local bus station has departures every 3 minutes almost all day. :-(
                          I’ll tinker with the change profile module to see if I can pause the Reslust module.
                          Cheers
                          /Sven
                            Alvinger @SvenT
                            @SvenT I think that if you just hide the module it will stop updating (but I’m not sure). Try it.
                            • N Offline
                              noorm91
                              Has anyone gotten ResRobot v2.1 to work?
                              If so how does your config look like?
                              I’m trying {from: “740000260”, to: “740000120”}, the rest is default except apiKey of course.
                                Alvinger @noorm91
                                @noorm91 Please post your entire config for ResRobot (with the secrets masked).
                                  Populus
                                  I quickly looked but couldn’t find if “Kalmar län” is included?
                                  A N 2 Replies Last reply Reply Quote 0
                                    Alvinger @Populus
                                    @Populus ResRobot covers all of Sweden as far as I know.
                                    • N Offline
                                      noorm91 @Alvinger
                                      @Alvinger It’s all good, thank you!
                                      It seems that you have to restart the rpi for every change you do.
                                      Is there a way to see how many changes you have to do?
                                      For example 1. Bus departure station > 2. Transit station > 3. Final destination.
                                      Would also be nice to see how many minutes it takes from A-B.
                                      • N Offline
                                        noorm91 @Populus
                                        @Populus which stations are you looking for in Kalmar?
                                          Populus @Alvinger
                                          It doesn’t appear to have my local stations. Our network is “Kalmar Länstrafik”.
                                          @noorm91 said in MMM-ResRobot - Public transport information for Sweden:
                                            Alvinger @Populus
                                            @Populus According to Samtrafikens webpage Kalmar länstrafik is part of their network and should be included. Is there a specific station I could try to look up?
                                            • 7 / 7
