    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 219.1k Views 28 Watching
      Alvinger @SvenT
      @SvenT I have experimented with a number of algorithms for minimizing updates but ended up with the one implemented. The current algorithm is:
      • If initial request, get updates from Trafiklab
      • If the first item in departure list (per routeId) is “old”, i.e. before cutoff time (now + skipMinutes), clear list (for routeId) and get updates from Trafiklab
      What the above means is that updates only occur ON ACTUAL DEPARTURES, e.g. if a bus departs every 15 minutes the module will get updates from Trafiklab every 15 minutes (per routeId). In rush hour this often means that the module get updates every minute but at night it might only update once per 60 minutes or longer (per routeId). This behavior has the benefit of automatically adjusting to rush hour and slow hours without user intervention or tweaking.
      If only one routeId is configured, the number of Trafiklab updates is usually way below the Trafiklab suggestions.
      /j
        SvenT @Alvinger
        @Alvinger I see.
        My local bus station has departures every 3 minutes almost all day. :-(
        I’ll tinker with the change profile module to see if I can pause the Reslust module.
        Cheers
        /Sven
          Alvinger @SvenT
          @SvenT I think that if you just hide the module it will stop updating (but I’m not sure). Try it.
          • N Offline
            noorm91
            Has anyone gotten ResRobot v2.1 to work?
            If so how does your config look like?
            I’m trying {from: “740000260”, to: “740000120”}, the rest is default except apiKey of course.
              Alvinger @noorm91
              @noorm91 Please post your entire config for ResRobot (with the secrets masked).
                Populus
                I quickly looked but couldn’t find if “Kalmar län” is included?
                A N 2 Replies Last reply Reply Quote 0
                  Alvinger @Populus
                  @Populus ResRobot covers all of Sweden as far as I know.
                  • N Offline
                    noorm91 @Alvinger
                    @Alvinger It’s all good, thank you!
                    It seems that you have to restart the rpi for every change you do.
                    Is there a way to see how many changes you have to do?
                    For example 1. Bus departure station > 2. Transit station > 3. Final destination.
                    Would also be nice to see how many minutes it takes from A-B.
                    • N Offline
                      noorm91 @Populus
                      @Populus which stations are you looking for in Kalmar?
                        Populus @Alvinger
                        @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
                        It doesn’t appear to have my local stations. Our network is “Kalmar Länstrafik”.
                        @noorm91 said in MMM-ResRobot - Public transport information for Sweden:
                          Alvinger @Populus
                          @Populus According to Samtrafikens webpage Kalmar länstrafik is part of their network and should be included. Is there a specific station I could try to look up?
                            Populus @Alvinger
                              axllin
                              Hi @Alvinger I have a question for you!
                              When I run npm run start I get the message:
                              [name-here]@raspberrypi:~/MagicMirror $ npm run start
                              > magicmirror@2.26.0 start
                              [11.02.2024 18:46.51.586] [LOG]   Starting MagicMirror: v2.26.0
                              [11.02.2024 18:46.51.592] [LOG]   Loading config ...
                              [11.02.2024 18:46.51.596] [DEBUG] config template file not exists, no envsubst
                              [11.02.2024 18:46.51.600] [LOG]   Loading module helpers ...
                              [11.02.2024 18:46.51.603] [LOG]   No helper found for module: alert.
                              [11.02.2024 18:46.51.649] [LOG]   Initializing new module helper ...
                              [11.02.2024 18:46.51.651] [LOG]   Module helper loaded: updatenotification
                              [11.02.2024 18:46.51.655] [LOG]   No helper found for module: clock.
                              [11.02.2024 18:46.51.659] [LOG]   No helper found for module: weather.
                              [11.02.2024 18:46.51.661] [WARN]  No /home/[name-here]/MagicMirror/js/../modules/MMM-ResRobot/MMM-ResRobot.js found for module: MMM-ResRobot.
                              [11.02.2024 18:46.51.663] [LOG]   No helper found for module: MMM-ResRobot.
                              The module doesn’t load and it posts something about not finding a .js for the module?
                              My current config in the config.js looks like this where I have pulled the station IDs from Trafiklab:
                                          module: "MMM-ResRobot",
                                          header: "Departures",
                                              routes: [
                                                  {from: "[removed]", to: "[removed]"},
                                              skipMinutes: 0,
                                              maximumEntries: 3,
                                              maximumDuration: 60,
                                                      getRelative: 10,
                                              truncateAfter: 5,
                                              truncateLineAfter: 5,
                                                          showTrack: true,
                                              coloredIcons: false,
                                              apiKey: "[my-api-key]",
                              Do you know what would be the issue with the module loading?
                              EDIT: I found the issue. I had the folder in /modules named as MMM-ResRobot-master. Removing the -master made it match the given module name in the config.js. It now works.
                                sdetweil @axllin
                                @axllin the
                                module name
                                folder name
                                modulename.js
                                and
                                register inside the modulename.js
                                must match exactly in text case
                                the message says we found the folder matching (cause there is an error for that too)
                                but not the js
                                • 7 / 7
