    Does this Module still work?
    Scheduled Pinned Locked Moved Education
    3 Posts 3 Posters 976 Views 3 Watching
      r3zi3lr
      Re: MMM-PrayerTime
      Aslaam Alaikum,
      Does anyone know if this module still works as I’ve added this to my config.js and it doesn’t do anything. i.e. Not showing in MagicMirror.
      Please see config below:
      module: “MMM-PrayerTime”,
      position: “bottom_left”, // This can be any of the regions. Best result is in the top_left/top_right.
      apiVersion: ‘1.0’, // please, leave unchanged. reserved for future use.
      lat: 51.506130, // latitude of your position (city)
      lon: -2.111366, // longitude of your position (city)
      timezone: “Europe/London”, // please refer to http://php.net/manual/en/timezones.php
      timeFormat: 24,
      method: 3,
      playAdzan: [‘fajr’, ‘dhuhr’, ‘asr’, ‘maghrib’, ‘isha’],
      notDisplayed: [‘midnight’, ‘sunset’],
      useUpdateInterval: true,
      updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
      animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
      language: “en”,
      showAdzanAlert: true,
      showTomorrow: true,
      vertical: true, // set false for horizontal view
      alertTimer: 15000
      Thank you
      wishmaster270W T 2 Replies Last reply Reply Quote 0
      • wishmaster270W Offline
        wishmaster270 Module Developer @r3zi3lr
        @r3zi3lr
        Hi, installed the module in my development environment a few minutes ago.
        Everything works but make sure to run
        npm install
        in the module folder.
        The installation instructions in the readme of the module are wrong at this point as only the “async” package will be installed.
        • T Offline
          tanvir586 @r3zi3lr
          @r3zi3lr walaikum assalam. I was using this module till last year. Was working absolutely fine. I don’t use it anymore. Location based prayer time is not accurate. Where do you live? May be I can help you to get a accurate one.
