    Online Radio
    52 Posts 4 Posters 31.0k Views 4 Watching
    • T
      tanvir586 @wishmaster270
      @wishmaster270 ok I’ll check shortly.
      • T
        @wishmaster270 Hi mate…
        wishmaster270W 1 Reply Last reply
        • wishmaster270W
          wishmaster270 Module Developer @tanvir586
          @tanvir586
          It looks like you use the right version but only the path in the “customCommand” option was wrong. With the following config it should work:
          		module: "MMM-MplayerRadio",
          		header: "Radio",
          		position: "top_center",
          			stations: [
          					title: "Almubarak",
          					url: "https://relay.emasjidlive.uk/almubarakradio",
          					logo: "https://almubarakradio.com/wp-content/uploads/2021/04/logorectangle-1024x326.png",
          					customCommand: "./modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash",
          					customCommandArgs: ["10", "30", "###URL###"],
          T 2 Replies Last reply
          • T
            @wishmaster270 Hi… the sound works perfectly. thank you very much. now just waiting now for the radio go offline and come back online. will text you back.
            • T
              @wishmaster270 Hi. The Radio just came back online but no luck. Is doesn’t come online itself.
              • wishmaster270W
                @tanvir586 Hi, bad to hear that.
                At the moment I do not have any other idea.
                T 1 Reply Last reply
                • T
                  @wishmaster270 That’s fine mate. Really appreciated you helping. Thank you very much.
                  • T
                    tanvir586
                    Hi mate started using your module back again. now I’m using a station which is 24/7. all working very good. just one help I need now. just wanna to reduce the size of the control Wrapper. I edit the mplayer-radio.css file. I was able to reduce the top part but the bottom part is not reducing. I edit
                    .mradio .controlWrapper {
                    padding-top: 5px;
                    width: 100%;
                    and add hight: 100%;
                    but it did not work. anything I can do on this?
                    • wishmaster270W
                      @tanvir586
                      first of all: Please do not edit any files in the module folder. You will get into problems with the next update. All CSS of the module can be overridden by copying the things you want to change to custom.css and edit it there.
                      second: Please use the ```YOUR CODE``` notation when pasting code.
                      Now to your problem :beaming_face_with_smiling_eyes:
                      The size of the controlWrapper depends of the buttons in it and their margin. So instead of changing the controlWrapper you could reduce the size of the buttons instead:
                      .mradio .controlWrapper .button {
                          height: 30px;
                          width: 30px;
                          margin-left: 5px;
                          margin-right: 5px;
                      If you want to reduce the size of the space between the stations and the buttons this is mostly the field where the stream information will be displayed (if provided and you are using mplayer to play, which you do not as i remember).
                      If do not want the stream information to be displayed you can set the the option showStreamInfo to false in the module configuration.
                      • T
                        @wishmaster270 Hi thanks mate 😊. I changed showStreamInfo to false and its worked well for me. Not changing anything. Thanks for this grate module.
                        N 1 Reply Last reply
                        • N
                          Nathaniel @tanvir586
                          @tanvir586
                          i also need that module can you share it with me
                          • wishmaster270W
                            wishmaster270 Module Developer @Nathaniel
                            @Nathaniel Hi,
                            the module ia available on Github MMM-MplayerRadio.
                            • 3 / 3
