    MMM-AVStock
    45 Posts 11 Posters 29.8k Views 10 Watching
    • thymonT Offline
      thymon @thymon
      @lavolp3
      Can you save help me ? :disappointed_but_relieved_face:
      • lavolp3L Offline
        lavolp3 Module Developer @thymon
        @thymon
        Try:
        1. setting width: 400 or any other value in the config.
        2. using other regions
        By default the module should expand to 100% width of it’s region. For some reason it expands to more than you would like.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        thymonT 1 Reply Last reply Reply Quote 0
        • thymonT Offline
          thymon @lavolp3
          @lavolp3 said in MMM-AVStock:
          width: 400
          same issue
          add : width: 400,
          testing with top left and top right
          IMG-3560
          lavolp3L 2 Replies Last reply Reply Quote 0
          • lavolp3L Offline
            @thymon if it’s still an issue can you post an issue on github?
            I forget this when reading it only here.
            • lavolp3L Offline
              @thymon as a follow-up explanation:
              The reason for what you have shown is that the table expands beyond its given width: 400 limit because … well tables don’t behave.
              Setting a smaller font (classes: 'xsmall') OR using less table headers (to make the table thinner) OR setting a larger width would only solve this.
              • lavolp3L Offline
                All,
                anyone volunteering to do some beta testing?
                I have pushed a new branch new_api including the IEX API. You would need an IEX API key (as described in the README) in ADDITION to the alphavantage key.
                Then you will have up-to-date quotes in table, ticker, and grid.
                Unfortunately I cannot switch completely to IEX, since fetching historical data is too expensive and would blow the free quota limit.
                git fetch
                git checkout new_api
                git pull
                Let me know if you are going to test this and if the results are satisfying.
                I will also look for another API to include all. Suggestions much appreciated!
                • thymonT Offline
                  thymon
                  Hello @lavolp3
                  How follow Bitcoin BTC/EUR ? I can’t find the symbol.
                  https://www.alphavantage.co/query?function=SYMBOL_SEARCH&keywords=bitcoin&apikey=NXXXXXXXXXXXXX
                  OK to test your beta :)
                  • lavolp3L Offline
                    @thymon said in MMM-AVStock:
                    Hello @lavolp3
                    Try the symbol BTCUSD. Works with many fx.
                      requiemmg @lavolp3
                      @lavolp3 Is this module still being maintained?
                        cml @requiemmg
                        @requiemmg
                        API calls required for this through "AlphaVantage " were free but are now behind a paywall. Currently broken in it’s current state.
                        • 3 / 3
