    MMM-AVStock
    45 Posts 11 Posters 30.4k Views 10 Watching
    • lavolp3L
      lavolp3 Module Developer @thymon
      @thymon
      Can you please post your config?
      Also look if any changes in custom.css or main.css may affect behavior in the region or module. If yes post these entries as well
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      thymonT 1 Reply Last reply
      • thymonT
        thymon @lavolp3
        @lavolp3
          module: "MMM-AVStock",
            apiKey : "HIDEN :-) ",
            coloredCandles : true,
                 symbols : ["C40.PAR"],
            alias: ["CAC40"],
                mode : "table",
                decimals: 2,
                poolInterval : 5 * 60 * 1000,
                tickerDuration: 5, // Ticker will be cycled once per this second.
                timeFormat: "DD-MM-YYYY HH:mm:ss",
        Nothing in custum.css for .MMM-AVStock
        • thymonT
          thymon @thymon
          @lavolp3
          Can you save help me ? :disappointed_but_relieved_face:
          lavolp3L 1 Reply Last reply
          • lavolp3L
            @thymon
            Try:
            1. setting width: 400 or any other value in the config.
            2. using other regions
            By default the module should expand to 100% width of it’s region. For some reason it expands to more than you would like.
            • thymonT
              thymon @lavolp3
              @lavolp3 said in MMM-AVStock:
              width: 400
              same issue
              add : width: 400,
              testing with top left and top right
              IMG-3560
              lavolp3L 2 Replies Last reply
              • lavolp3L
                @thymon if it’s still an issue can you post an issue on github?
                I forget this when reading it only here.
                • lavolp3L
                  @thymon as a follow-up explanation:
                  The reason for what you have shown is that the table expands beyond its given width: 400 limit because … well tables don’t behave.
                  Setting a smaller font (classes: 'xsmall') OR using less table headers (to make the table thinner) OR setting a larger width would only solve this.
                  • lavolp3L
                    All,
                    anyone volunteering to do some beta testing?
                    I have pushed a new branch new_api including the IEX API. You would need an IEX API key (as described in the README) in ADDITION to the alphavantage key.
                    Then you will have up-to-date quotes in table, ticker, and grid.
                    Unfortunately I cannot switch completely to IEX, since fetching historical data is too expensive and would blow the free quota limit.
                    git fetch
                    git checkout new_api
                    git pull
                    Let me know if you are going to test this and if the results are satisfying.
                    I will also look for another API to include all. Suggestions much appreciated!
                    • thymonT
                      thymon
                      Hello @lavolp3
                      How follow Bitcoin BTC/EUR ? I can’t find the symbol.
                      https://www.alphavantage.co/query?function=SYMBOL_SEARCH&keywords=bitcoin&apikey=NXXXXXXXXXXXXX
                      OK to test your beta :)
                      • lavolp3L
                        @thymon said in MMM-AVStock:
                        Hello @lavolp3
                        Try the symbol BTCUSD. Works with many fx.
                        R 1 Reply Last reply
                          requiemmg @lavolp3
                          @lavolp3 Is this module still being maintained?
                          C 1 Reply Last reply
                            cml @requiemmg
                            @requiemmg
                            API calls required for this through "AlphaVantage " were free but are now behind a paywall. Currently broken in it’s current state.
                            • 3 / 3
