    MMM-AVStock
    45 Posts 11 Posters 30.4k Views 10 Watching
    • thymonT
      thymon @lavolp3
      @lavolp3 nice ! :)
      • thymonT
        thymon @lavolp3
        @lavolp3 said in MMM-AVStock:
        @thymon Thank you, working on it.
        Hi @lavolp3 some news about this issue ?
        Thx :)
        lavolp3L 1 Reply Last reply
        • lavolp3L
          lavolp3 Module Developer @thymon
          @thymon pushed an update yesterday. Try it out and let meknow if it works now
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          thymonT 1 Reply Last reply
          • thymonT
            thymon @lavolp3
            Same issue.
            • lavolp3L
              @thymon
              Can you please post your config?
              Also look if any changes in custom.css or main.css may affect behavior in the region or module. If yes post these entries as well
              • thymonT
                thymon @lavolp3
                @lavolp3
                  module: "MMM-AVStock",
                    apiKey : "HIDEN :-) ",
                    coloredCandles : true,
                         symbols : ["C40.PAR"],
                    alias: ["CAC40"],
                        mode : "table",
                        decimals: 2,
                        poolInterval : 5 * 60 * 1000,
                        tickerDuration: 5, // Ticker will be cycled once per this second.
                        timeFormat: "DD-MM-YYYY HH:mm:ss",
                Nothing in custum.css for .MMM-AVStock
                • thymonT
                  thymon @thymon
                  @lavolp3
                  Can you save help me ? :disappointed_but_relieved_face:
                  • lavolp3L
                    @thymon
                    Try:
                    1. setting width: 400 or any other value in the config.
                    2. using other regions
                    By default the module should expand to 100% width of it’s region. For some reason it expands to more than you would like.
                    • thymonT
                      thymon @lavolp3
                      width: 400
                      same issue
                      add : width: 400,
                      testing with top left and top right
                      IMG-3560
                      lavolp3L 2 Replies Last reply
                      • lavolp3L
                        @thymon if it’s still an issue can you post an issue on github?
                        I forget this when reading it only here.
                        • lavolp3L
                          @thymon as a follow-up explanation:
                          The reason for what you have shown is that the table expands beyond its given width: 400 limit because … well tables don’t behave.
                          Setting a smaller font (classes: 'xsmall') OR using less table headers (to make the table thinner) OR setting a larger width would only solve this.
                          • lavolp3L
                            All,
                            anyone volunteering to do some beta testing?
                            I have pushed a new branch new_api including the IEX API. You would need an IEX API key (as described in the README) in ADDITION to the alphavantage key.
                            Then you will have up-to-date quotes in table, ticker, and grid.
                            Unfortunately I cannot switch completely to IEX, since fetching historical data is too expensive and would blow the free quota limit.
                            git fetch
                            git checkout new_api
                            git pull
                            Let me know if you are going to test this and if the results are satisfying.
                            I will also look for another API to include all. Suggestions much appreciated!
                            • thymonT
                              thymon
                              Hello @lavolp3
                              How follow Bitcoin BTC/EUR ? I can’t find the symbol.
                              https://www.alphavantage.co/query?function=SYMBOL_SEARCH&keywords=bitcoin&apikey=NXXXXXXXXXXXXX
                              OK to test your beta :)
                              • lavolp3L
                                @thymon said in MMM-AVStock:
                                Hello @lavolp3
                                Try the symbol BTCUSD. Works with many fx.
                                R 1 Reply Last reply
                                  requiemmg @lavolp3
                                  @lavolp3 Is this module still being maintained?
                                  C 1 Reply Last reply
                                    cml @requiemmg
                                    @requiemmg
                                    API calls required for this through "AlphaVantage " were free but are now behind a paywall. Currently broken in it’s current state.
                                    • 2 / 3
