    MMM-AVStock
    45 Posts 11 Posters 29.8k Views 10 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @Guest
      @sean
      I knew you could do it faster and better than I could!!! :smiling_face_with_sunglasses:
      Jim Hallock - 1995
      • lavolp3L Offline
        lavolp3 Module Developer
        @Sean Thanks for doing this! Was already looking for some time for exactly this!
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • N Offline
          nobita @lavolp3
          @Sean
          How to set width of this module match with my display
          (how to adjust it)
          • cowboysdudeC Offline
            cowboysdude Module Developer @nobita
            @nobita The easy way is to use your custom.css file like this:
            .MMM-AVStock {
             width: 500px; //or whatever you want....can also be a % like this 100% or 100vh
            vw: hundredths of the viewport width.
            vh: hundredths of the viewport height.
            vm: hundredths of whichever is smaller, the viewport width or height.
            • N Offline
              nobita @cowboysdude
              @cowboysdude
              thanks ,easy way
                A Former User
                UPDATED
                1.1.0
                • Fixed : Alphavantage has changed their API quota rule for free Account. (500 requests limit per day)
                • included decimals option and optimized loading time (by @lavolp3)
                • ncluded candle stick charts for series graph(by @lavolp3)
                • lavolp3L Offline
                  For all you chart lovers and technical freaks out there the AVStock module now has fancy candle stick charts (also available in black+white).
                  Isn’t this just beautiful??
                  Sorry, needed to beat the drum a bit.
                  Planned PR’s:
                  • Charts for 5min, 15min, 60min
                  • include startdate and enddate for chart.
                  • include max and min value labels in chart.
                  • K Offline
                    killing joke
                    Hi @ all,
                    I have a problem and hope that you can help me.
                    I installed the module and put some stocks (8) in it. But unfortunately it shows the values of the previous day!?
                    For example the Petrobras stock: today´s closure at Frankfurt stock exchange is 3,34 Euro but it shows the value from yesterday.
                    Any ideas ?
                    Thanks in advance…
                    Daniel
                      bclinton11
                      I have been pulling my hair out…I am trying to get it to display the dow jones average and the the nasdaq. I have tried about every option I know of ^DJI. .DJI, ^IXIC, .IXIC among others. It is always blanks. All of the other ticker symbols work fine…it’s just those 2.
                      Looking for any suggestions :)
                      lavolp3L S 2 Replies Last reply Reply Quote 0
                      • lavolp3L Offline
                        lavolp3 Module Developer @bclinton11
                        @bclinton11 Just read that DJI stopped working this April.
                        So I don’t know either which works now. Can confirm that none of the above work.
                        • lavolp3L Offline
                          lavolp3 Module Developer @killing joke
                          @killing-joke HI Daniel,
                          at which time of day do you have the data of the last day.
                          And what is the stock symbol you use for Petrobras?
                            sdetweil @bclinton11
                            @bclinton11 avstocks does not display nasdaq, only dow
                            • K Offline
                              killing joke @lavolp3
                              Hi @lavolp3 ,
                              the Symbol of Petrobras is “PJXC.F” but it occours on all others as well.
                              The time I took the screenshot was arround 22:00 (11PM) in Germany.
                              Therefore I thought it should be the actual stock value of the day (the stock exchange Frankfurt was closed at this time, so the last value) and the stock value of the previous day…
                              • lavolp3L Offline
                                @killing-joke I can’t even call this ticker.
                                Can you give me a URL?
                                Otherwise I’ll try to include the ticker as soon as I have the new node_helper version (using different calls) finished.
                                  bclinton11 @sdetweil
                                  @sdetweil Thanks! What is the DOW symobol?
                                    @bclinton11 no idea. What I was saying is the you can only look up Dow stocks. Not nasdaq
                                    • lavolp3L Offline
                                      @sdetweil that’s not true. AV also shows lots of nasdaq tickers. Even surprisingly many german stocks.
                                        sdetweil @lavolp3
                                        @lavolp3 if you lookup the API it says dj only. I need another key for nasdaq.
                                        I wrote the code for another platform
                                        lavolp3L 2 Replies Last reply Reply Quote 0
                                        • lavolp3L Offline
                                          @sdetweil sorry don’t know where you have that from.
                                          My key works well with a range of Nasdaq stocks.
                                          • lavolp3L Offline
                                            @sdetweil are you talking about REALTIME data? Then I understand. Yes, AV does not provide realtime data for Nasdaq stocks. Who cares? Not many free services do.
