    MMM-AVStock
    45 Posts 11 Posters 30.4k Views 10 Watching
      sdetweil @lavolp3
      @lavolp3 if you lookup the API it says dj only. I need another key for nasdaq.
      I wrote the code for another platform
      lavolp3L 2 Replies Last reply
      • lavolp3L
        @sdetweil sorry don’t know where you have that from.
        My key works well with a range of Nasdaq stocks.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L
          @sdetweil are you talking about REALTIME data? Then I understand. Yes, AV does not provide realtime data for Nasdaq stocks. Who cares? Not many free services do.
            sdetweil @lavolp3
            @lavolp3
            https://www.alphavantage.co/documentation/
            if you are interested in realtime intraday data for Nasdaq-listed securities, we have partnered with Polygon.io, a leading provider of realtime market data that counts Google and Robinhood as its customers. Specifically, this Intraday Time Series API maps directly to Polygon's Aggregates API.
            Alpha Vantage users will enjoy a lifetime 10% discount for their Polygon subscriptions. To unlock the discount, simply sign up for Polygon using your Alpha Vantage user email and enter the code ALPHAV on the subscription page.
              sdetweil @lavolp3
              @lavolp3 said in MMM-AVStock:
              what other data is important?
              lavolp3L 1 Reply Last reply
              • lavolp3L
                @sdetweil nasdaq data is 15 min delayed. I dont care. I want to see how the stock develops today, not in this minute. I want to see how it has developed over the lest days and where it is e.g. in relation to it’s SMA200.
                I’m not daytrading in front of my mirror :-).
                I would rather ask you why is realtime data important in front of your mirror.
                Reply Quote -1
                  sdetweil @lavolp3
                  @lavolp3 i didn’t realize there were different timescale data. i don’t use it. i list stocks, only as a daily thing.
                    bclinton11 @lavolp3
                    @lavolp3 Thanks for that info…
                    • K
                      killing joke @lavolp3
                      @lavolp3
                      Sorry for the delayed answer.
                      If I type “PJXC” into a search engine (e.g. google) I got the stock for Pedrobras. I thought the “.F” delivers the stock value for the stock exchange for Frankfurt…
                      • thymonT
                        thymon
                        @lavolp3
                        There is a width bug since the last update (09/02/2020).
                        alt text
                        • lavolp3L
                          lavolp3 Module Developer @thymon
                          @thymon Thank you, working on it.
                          thymonT 2 Replies Last reply
                          • thymonT
                            thymon @lavolp3
                            @lavolp3 nice ! :)
                            • thymonT
                              thymon @lavolp3
                              Hi @lavolp3 some news about this issue ?
                              Thx :)
                              • lavolp3L
                                @thymon pushed an update yesterday. Try it out and let meknow if it works now
                                thymonT 1 Reply Last reply
                                • thymonT
                                  thymon @lavolp3
                                  Same issue.
                                  • lavolp3L
                                    @thymon
                                    Can you please post your config?
                                    Also look if any changes in custom.css or main.css may affect behavior in the region or module. If yes post these entries as well
                                    • thymonT
                                      thymon @lavolp3
                                      @lavolp3
                                        module: "MMM-AVStock",
                                          apiKey : "HIDEN :-) ",
                                          coloredCandles : true,
                                               symbols : ["C40.PAR"],
                                          alias: ["CAC40"],
                                              mode : "table",
                                              decimals: 2,
                                              poolInterval : 5 * 60 * 1000,
                                              tickerDuration: 5, // Ticker will be cycled once per this second.
                                              timeFormat: "DD-MM-YYYY HH:mm:ss",
                                      Nothing in custum.css for .MMM-AVStock
                                      • thymonT
                                        thymon @thymon
                                        @lavolp3
                                        Can you save help me ? :disappointed_but_relieved_face:
                                        • lavolp3L
                                          @thymon
                                          Try:
                                          1. setting width: 400 or any other value in the config.
                                          2. using other regions
                                          By default the module should expand to 100% width of it’s region. For some reason it expands to more than you would like.
                                          • thymonT
                                            thymon @lavolp3
                                            width: 400
                                            same issue
                                            add : width: 400,
                                            testing with top left and top right
                                            IMG-3560
                                            • 2 / 3
