    MMM-AVStock
    45 Posts 11 Posters 29.4k Views 10 Watching
      sdetweil @lavolp3
      @lavolp3 said in MMM-AVStock:
      are you talking about REALTIME data
      what other data is important?
      • lavolp3L Offline
        @sdetweil nasdaq data is 15 min delayed. I dont care. I want to see how the stock develops today, not in this minute. I want to see how it has developed over the lest days and where it is e.g. in relation to it’s SMA200.
        I’m not daytrading in front of my mirror :-).
        I would rather ask you why is realtime data important in front of your mirror.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        S 1 Reply Last reply Reply Quote -1
          sdetweil @lavolp3
          @lavolp3 i didn’t realize there were different timescale data. i don’t use it. i list stocks, only as a daily thing.
            bclinton11 @lavolp3
            @lavolp3 Thanks for that info…
            • K Offline
              killing joke @lavolp3
              @lavolp3
              Sorry for the delayed answer.
              If I type “PJXC” into a search engine (e.g. google) I got the stock for Pedrobras. I thought the “.F” delivers the stock value for the stock exchange for Frankfurt…
              • thymonT Offline
                thymon
                @lavolp3
                There is a width bug since the last update (09/02/2020).
                alt text
                • lavolp3L Offline
                  lavolp3 Module Developer @thymon
                  @thymon Thank you, working on it.
                  thymonT 2 Replies Last reply Reply Quote 0
                  • thymonT Offline
                    thymon @lavolp3
                    @lavolp3 nice ! :)
                    • thymonT Offline
                      thymon @lavolp3
                      Hi @lavolp3 some news about this issue ?
                      Thx :)
                      • lavolp3L Offline
                        @thymon pushed an update yesterday. Try it out and let meknow if it works now
                        thymonT 1 Reply Last reply Reply Quote 0
                        • thymonT Offline
                          thymon @lavolp3
                          Same issue.
                          • lavolp3L Offline
                            @thymon
                            Can you please post your config?
                            Also look if any changes in custom.css or main.css may affect behavior in the region or module. If yes post these entries as well
                            • thymonT Offline
                              thymon @lavolp3
                              @lavolp3
                                module: "MMM-AVStock",
                                  apiKey : "HIDEN :-) ",
                                  coloredCandles : true,
                                       symbols : ["C40.PAR"],
                                  alias: ["CAC40"],
                                      mode : "table",
                                      decimals: 2,
                                      poolInterval : 5 * 60 * 1000,
                                      tickerDuration: 5, // Ticker will be cycled once per this second.
                                      timeFormat: "DD-MM-YYYY HH:mm:ss",
                              Nothing in custum.css for .MMM-AVStock
                              • thymonT Offline
                                thymon @thymon
                                @lavolp3
                                Can you save help me ? :disappointed_but_relieved_face:
                                • lavolp3L Offline
                                  @thymon
                                  Try:
                                  1. setting width: 400 or any other value in the config.
                                  2. using other regions
                                  By default the module should expand to 100% width of it’s region. For some reason it expands to more than you would like.
                                  • thymonT Offline
                                    thymon @lavolp3
                                    width: 400
                                    same issue
                                    add : width: 400,
                                    testing with top left and top right
                                    IMG-3560
                                    lavolp3L 2 Replies Last reply Reply Quote 0
                                    • lavolp3L Offline
                                      @thymon if it’s still an issue can you post an issue on github?
                                      I forget this when reading it only here.
                                      • lavolp3L Offline
                                        @thymon as a follow-up explanation:
                                        The reason for what you have shown is that the table expands beyond its given width: 400 limit because … well tables don’t behave.
                                        Setting a smaller font (classes: 'xsmall') OR using less table headers (to make the table thinner) OR setting a larger width would only solve this.
                                        • lavolp3L Offline
                                          All,
                                          anyone volunteering to do some beta testing?
                                          I have pushed a new branch new_api including the IEX API. You would need an IEX API key (as described in the README) in ADDITION to the alphavantage key.
                                          Then you will have up-to-date quotes in table, ticker, and grid.
                                          Unfortunately I cannot switch completely to IEX, since fetching historical data is too expensive and would blow the free quota limit.
                                          git fetch
                                          git checkout new_api
                                          git pull
                                          Let me know if you are going to test this and if the results are satisfying.
                                          I will also look for another API to include all. Suggestions much appreciated!
                                          • thymonT Offline
                                            thymon
                                            Hello @lavolp3
                                            How follow Bitcoin BTC/EUR ? I can’t find the symbol.
                                            https://www.alphavantage.co/query?function=SYMBOL_SEARCH&keywords=bitcoin&apikey=NXXXXXXXXXXXXX
                                            OK to test your beta :)
                                            • 2 / 3
