    MMM-AVStock
    45 Posts 11 Posters 30.4k Views 10 Watching
    • lavolp3L
      @sdetweil nasdaq data is 15 min delayed. I dont care. I want to see how the stock develops today, not in this minute. I want to see how it has developed over the lest days and where it is e.g. in relation to it’s SMA200.
      I’m not daytrading in front of my mirror :-).
      I would rather ask you why is realtime data important in front of your mirror.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      Reply Quote -1
        sdetweil @lavolp3
        @lavolp3 i didn’t realize there were different timescale data. i don’t use it. i list stocks, only as a daily thing.
          bclinton11 @lavolp3
          @lavolp3 Thanks for that info…
          • K
            killing joke @lavolp3
            @lavolp3
            Sorry for the delayed answer.
            If I type “PJXC” into a search engine (e.g. google) I got the stock for Pedrobras. I thought the “.F” delivers the stock value for the stock exchange for Frankfurt…
            • thymonT
              thymon
              @lavolp3
              There is a width bug since the last update (09/02/2020).
              alt text
              lavolp3L 1 Reply Last reply
              • lavolp3L
                lavolp3 Module Developer @thymon
                @thymon Thank you, working on it.
                thymonT 2 Replies Last reply
                • thymonT
                  thymon @lavolp3
                  @lavolp3 nice ! :)
                  • thymonT
                    thymon @lavolp3
                    @lavolp3 said in MMM-AVStock:
                    Hi @lavolp3 some news about this issue ?
                    Thx :)
                    • lavolp3L
                      @thymon pushed an update yesterday. Try it out and let meknow if it works now
                      thymonT 1 Reply Last reply
                      • thymonT
                        thymon @lavolp3
                        Same issue.
                        • lavolp3L
                          @thymon
                          Can you please post your config?
                          Also look if any changes in custom.css or main.css may affect behavior in the region or module. If yes post these entries as well
                          • thymonT
                            thymon @lavolp3
                            @lavolp3
                              module: "MMM-AVStock",
                                apiKey : "HIDEN :-) ",
                                coloredCandles : true,
                                     symbols : ["C40.PAR"],
                                alias: ["CAC40"],
                                    mode : "table",
                                    decimals: 2,
                                    poolInterval : 5 * 60 * 1000,
                                    tickerDuration: 5, // Ticker will be cycled once per this second.
                                    timeFormat: "DD-MM-YYYY HH:mm:ss",
                            Nothing in custum.css for .MMM-AVStock
                            • thymonT
                              thymon @thymon
                              @lavolp3
                              Can you save help me ? :disappointed_but_relieved_face:
                              • lavolp3L
                                @thymon
                                Try:
                                1. setting width: 400 or any other value in the config.
                                2. using other regions
                                By default the module should expand to 100% width of it’s region. For some reason it expands to more than you would like.
                                • thymonT
                                  thymon @lavolp3
                                  width: 400
                                  same issue
                                  add : width: 400,
                                  testing with top left and top right
                                  IMG-3560
                                  lavolp3L 2 Replies Last reply
                                  • lavolp3L
                                    @thymon if it’s still an issue can you post an issue on github?
                                    I forget this when reading it only here.
                                    • lavolp3L
                                      @thymon as a follow-up explanation:
                                      The reason for what you have shown is that the table expands beyond its given width: 400 limit because … well tables don’t behave.
                                      Setting a smaller font (classes: 'xsmall') OR using less table headers (to make the table thinner) OR setting a larger width would only solve this.
                                      • lavolp3L
                                        All,
                                        anyone volunteering to do some beta testing?
                                        I have pushed a new branch new_api including the IEX API. You would need an IEX API key (as described in the README) in ADDITION to the alphavantage key.
                                        Then you will have up-to-date quotes in table, ticker, and grid.
                                        Unfortunately I cannot switch completely to IEX, since fetching historical data is too expensive and would blow the free quota limit.
                                        git fetch
                                        git checkout new_api
                                        git pull
                                        Let me know if you are going to test this and if the results are satisfying.
                                        I will also look for another API to include all. Suggestions much appreciated!
                                        • thymonT
                                          thymon
                                          Hello @lavolp3
                                          How follow Bitcoin BTC/EUR ? I can’t find the symbol.
                                          https://www.alphavantage.co/query?function=SYMBOL_SEARCH&keywords=bitcoin&apikey=NXXXXXXXXXXXXX
                                          OK to test your beta :)
                                          • lavolp3L
                                            @thymon said in MMM-AVStock:
                                            Hello @lavolp3
                                            Try the symbol BTCUSD. Works with many fx.
                                            R 1 Reply Last reply
                                            • 2 / 3
