    Camera via browser
    4 Posts 2 Posters 1.6k Views 2 Watching
    • A
      Alyx
      Hi All,
      Just wondering the plausibility of the following scenario. I have MM running on my homelab and connect into it via an old PC (soon will be an old phone for power reasons, fml). Essentially this PC has a webcam connected to it for the intended use taking pictures of course.
      So the current solutions come down to modules such as SelfieShoot that uses local resources to the MM instance or deploy my webcam as a IP cam and then use a remoting module to display that feed… If there is another way please please let me know! Also yes the SelfieShoot moudule is likely not to work but I’m hopeful.
      The ideal scenario is if theres a way for the MM to request webcam access via the browser and then store that result locally on the MM container.
      bugsounetB 1 Reply Last reply
      • bugsounetB
        bugsounet Banned @Alyx
        @Alyx maybe it’s your chance… I code it with extra plug-in
        Just wait a little days and i will finish
        A 2 Replies Last reply
        Reply Quote 2
        • A
          Alyx @bugsounet
          @bugsounet You would be forever amazing if you could do this :)
          • A
            Alyx @bugsounet
            @bugsounet Hello, just following up on this and if you happened to have found the time?
