    Display different Roomtemperature on MagicMirror
    31 Posts 4 Posters 16.7k Views 4 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @Xilef
      @Xilef
      Perfect. This is the right setting.
      You need to replace the ##, too.
      It will look something like:
      const char* ssid     = "MY_WIFI_NETWORK";
      const char* password = "123ABC456";
      IPAddress local_IP(192, 168, 178, 106);
      IPAddress gateway(192, 168, 178, 1);
      IPAddress subnet(255, 255, 255, 0);
      IPAddress primaryDNS(192, 168, 178, 1);
      IPAddress secondaryDNS(8, 8, 8, 8);
      To check if everything is set up correctly you can run:
      /bin/nc -w3 192.168.178.106 80
      XilefX 1 Reply Last reply Reply Quote 0
      • XilefX Offline
        Xilef @wishmaster270
        @wishmaster270 the “/bin/nc -w3 192.168.178.106 80” command on the serial monitor message line?
        I would suggest to remove the clamp behind the ; ??
          @Xilef
          Sorry, my fault. You need to change line 52 to:
          if (!bme.begin(0x76)) {
          Copy&Paste mistake of me
          • XilefX Offline
            @wishmaster270 i installed the module, but i cant display the data
            what am i doing wrong, ah the esp32 says he couldnt find a sensor, thats weird
            (edit: i tried another one and it worked this time)
              @Xilef
              You will need the MMM-Temperature module and not the Embed module as you do not want to display a website but parse the JSON data object and display its contents.
              The config will look something like:
              			module: "MMM-Temperature",
              			position: "bottom_right",
              				sensors: [
              					    script: "/bin/nc",
              					    args: "-w3 192.168.178.106"
              But you will need to fix the missing sensor first.
              Can you please check your wiring and use this sketch instead of the other one. I only removed one line which i do not think is the problem but i can not test the sketch at the moment.
              #include <WiFi.h>
              #include <Wire.h>
              #include <Adafruit_Sensor.h>
              #include <Adafruit_BME280.h>
              const char* ssid     = "##ADD_WIFI_SSID_HERE";
              const char* password = "##ADD_WIFI_PASSWORD_HERE";
              //ENTER STATIC IP OF THE ESP32 BOARD HERE
              IPAddress local_IP(192, 168, 0, 2);
              IPAddress gateway(192, 168, 0, 1);
              IPAddress primaryDNS(192, 168, 0, 1);
              Adafruit_BME280 bme;
              WiFiServer server(80);
              void setup()
                Serial.begin(115200);
                if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
                  Serial.println("STA Failed to configure");
                Serial.print("Connecting to ");
                Serial.println(ssid);
                WiFi.begin(ssid, password);
                while (WiFi.status() != WL_CONNECTED) {
                  delay(500);
                  Serial.print(".");
                Serial.println("");
                Serial.println("WiFi connected!");
                Serial.print("IP address: ");
                Serial.println(WiFi.localIP());
                Serial.print("ESP Mac Address: ");
                Serial.println(WiFi.macAddress());
                Serial.print("Subnet Mask: ");
                Serial.println(WiFi.subnetMask());
                Serial.print("Gateway IP: ");
                Serial.println(WiFi.gatewayIP());
                Serial.print("DNS: ");
                Serial.println(WiFi.dnsIP());
                  Serial.println("Couldn't find sensor!");
                  while (1);
                server.begin();
              void loop()
                float temp = bme.readTemperature();
                float tempf = temp * 1.8 + 32;
                float rel_hum = bme.readHumidity();
                WiFiClient client = server.available();
                if (client) {
                  Serial.println("New Client.");
                  client.println("{");
                  client.print("  \"temperature_c\": ");
                  client.print(temp);
                  client.println(",");
                  client.print("  \"temperature_f\": ");
                  client.print(tempf);
                  client.print("  \"humidity\": ");
                  client.print(rel_hum);
                  client.println("  \"error\": false");
                  client.println("}");
                  client.stop();
                  Serial.println("Client disconnected.");
                  Serial.println("");
                delay(100);
              XilefX 2 Replies Last reply Reply Quote 0
              • XilefX Offline
                @wishmaster270 i connected an other sensor and it doesnt showed me the error message, i will try the sketch tomorrow, the MMM_Temperature module is installed and works, but doesnt show any data, im gona try to fix it tomorrow
                • XilefX Offline
                  @wishmaster270 everything worked, you just forgot to add the “80” here:
                  i just set up a second sensor and cloned the module
                  if i go into my browser and type the two different IPs every sensor shows his own data, but the mirror displays 2times the data of sensor 2:
                  (sensor1: “test” | sensor2: “test2”)
                  how do i fix that?
                    @Xilef Perfect. One step further.
                    You only need one instance of the module. So your config will look something like:
                    			position: "middle_center",
                    				sensors: [
                    					    script: "/bin/nc",
                    					    args: "-w3 192.168.178.106 80"
                    					    script: "/bin/nc",
                    					    args: "-w3 192.168.178.108 80"
                    • XilefX Offline
                      @wishmaster270 yes, it works
                      and in the future i can experiment with the MMM-ValuesByNotification Module to customize the module, right?
                      and a big thank you for the help and the quick reply
                        @Xilef Perfect.
                        Yes, the ValuesByNotification module is very powerful but the configuration can be get complex very quickly. You will need my other module CommandToNotification, too.
