    Monitor Samsung P2470H at home
    12 Posts 6 Posters 8.3k Views 5 Watching
    • foxF Offline
      fox @schlachtkreuzer6
      @schlachtkreuzer6 said in Monitor Samsung P2470H at home:
      @fox https://forum.magicmirror.builders/topic/1011/two-way-mirror-order-in-germany/155
      thx, just found it. But ~9m² away from order :-(. And
      • http://glas-per-klick.de/spiegel-antikspiegel/spionspiegel.html
      • http://myspiegel.de/ (not very good references…)
        https://forum.magicmirror.builders/topic/756/where-to-get-cheap-acrylic-mirror-from-in-germany/2
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        sero
        We are not 9m² away from being able to order, it will just get cheaper with more than 20m². (There was an update to the conditions)
        From what I understand, ordering is possible with the current amount already.
        • foxF Offline
          fox
          Ok, i posted in the thread, lets see the progress.
          Another thing is, my monitor has a touchpad connected with flat wire to the frame alt text
          I am just wondering how the raspi could even switch the monitor on or how i will control the Magic Mirror ;)
          schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
          • schlachtkreuzer6S Offline
            schlachtkreuzer6 @fox
            @fox maybe you can hack the soft buttons, and emulate them with the pi over gpio pins, write some code …
            foxF 1 Reply Last reply Reply Quote 0
            • foxF Offline
              Good idea this could work. Even when the brightness / contrast is adjusted i need only P_ON/OFF, and i can put a signal on the GPIO Pin when the raspi boots, soldered parallel on the wire.
              Thx for this idea!
              • K Offline
                KrawallKurt
                Remember, the pi GPIOs can only handle 3V3. Check the voltage of the monitor buttons with a multimeter before soldering. You will likely need a level shifter.
                • foxF Offline
                  fox
                  I have disassembled the monitor and have seen that I can’t give the signals per gpio.
                  It’s a serial connection and I can’t simulate the protocol.
                  So, is it possible to use the LCD Screen?
                  It’s a m240hw01 v2
                  • bheplerB Offline
                    bhepler Module Developer @fox
                    @fox It’s possible. If you configure your Pi to turn off the signal to the HDMI port, the monitor should shut off automatically. It should remain off until it detects a signal again, whereupon it will turn itself back on.
                    The MotionDetection module can do this for you with a Raspberry Pi camera. Otherwise, there is a module for using a PIR sensor.
