    Monitor Samsung P2470H at home
    12 Posts 6 Posters 9.7k Views 5 Watching
    • F
      fox
      i have read today the first time from this project :). So its my first post.
      I want to start direct so i found the mentioned monitor in my cellar.
      Is it suitable? Any ideas or experiences?
      Best regards
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        broberg Project Sponsor
        Should work just fine, it has HDMI and audio out, and is a mere 54mm thick without foot.
        Go for it.
        • F
          fox
          Thank you @broberg, i just started to disassembly it. Looks quite thick, so i need to make a big frame.
          Next step will be the frame and look for a appropriate mirrorsupplier in germany
            schlachtkreuzer6 @fox
            @fox https://forum.magicmirror.builders/topic/1011/two-way-mirror-order-in-germany/155
            • F
              fox @schlachtkreuzer6
              @schlachtkreuzer6 said in Monitor Samsung P2470H at home:
              thx, just found it. But ~9m² away from order :-(. And
              • http://glas-per-klick.de/spiegel-antikspiegel/spionspiegel.html
              • http://myspiegel.de/ (not very good references…)
                https://forum.magicmirror.builders/topic/756/where-to-get-cheap-acrylic-mirror-from-in-germany/2
                sero
                We are not 9m² away from being able to order, it will just get cheaper with more than 20m². (There was an update to the conditions)
                From what I understand, ordering is possible with the current amount already.
                • F
                  fox
                  Ok, i posted in the thread, lets see the progress.
                  Another thing is, my monitor has a touchpad connected with flat wire to the frame alt text
                  I am just wondering how the raspi could even switch the monitor on or how i will control the Magic Mirror ;)
                    @fox maybe you can hack the soft buttons, and emulate them with the pi over gpio pins, write some code …
                    • F
                      Good idea this could work. Even when the brightness / contrast is adjusted i need only P_ON/OFF, and i can put a signal on the GPIO Pin when the raspi boots, soldered parallel on the wire.
                      Thx for this idea!
                      • K
                        KrawallKurt
                        Remember, the pi GPIOs can only handle 3V3. Check the voltage of the monitor buttons with a multimeter before soldering. You will likely need a level shifter.
                        • F
                          fox
                          I have disassembled the monitor and have seen that I can’t give the signals per gpio.
                          It’s a serial connection and I can’t simulate the protocol.
                          So, is it possible to use the LCD Screen?
                          It’s a m240hw01 v2
                            bhepler Module Developer @fox
                            @fox It’s possible. If you configure your Pi to turn off the signal to the HDMI port, the monitor should shut off automatically. It should remain off until it detects a signal again, whereupon it will turn itself back on.
                            The MotionDetection module can do this for you with a Raspberry Pi camera. Otherwise, there is a module for using a PIR sensor.
