    Monitor Samsung P2470H at home
    12 Posts 6 Posters 9.7k Views 5 Watching
    • F
      fox
      Thank you @broberg, i just started to disassembly it. Looks quite thick, so i need to make a big frame.
      Next step will be the frame and look for a appropriate mirrorsupplier in germany
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        schlachtkreuzer6 @fox
        @fox https://forum.magicmirror.builders/topic/1011/two-way-mirror-order-in-germany/155
        • F
          fox @schlachtkreuzer6
          @schlachtkreuzer6 said in Monitor Samsung P2470H at home:
          thx, just found it. But ~9m² away from order :-(. And
          • http://glas-per-klick.de/spiegel-antikspiegel/spionspiegel.html
          • http://myspiegel.de/ (not very good references…)
            https://forum.magicmirror.builders/topic/756/where-to-get-cheap-acrylic-mirror-from-in-germany/2
            sero
            We are not 9m² away from being able to order, it will just get cheaper with more than 20m². (There was an update to the conditions)
            From what I understand, ordering is possible with the current amount already.
            • F
              fox
              Ok, i posted in the thread, lets see the progress.
              Another thing is, my monitor has a touchpad connected with flat wire to the frame alt text
              I am just wondering how the raspi could even switch the monitor on or how i will control the Magic Mirror ;)
                @fox maybe you can hack the soft buttons, and emulate them with the pi over gpio pins, write some code …
                • F
                  Good idea this could work. Even when the brightness / contrast is adjusted i need only P_ON/OFF, and i can put a signal on the GPIO Pin when the raspi boots, soldered parallel on the wire.
                  Thx for this idea!
                  • K
                    KrawallKurt
                    Remember, the pi GPIOs can only handle 3V3. Check the voltage of the monitor buttons with a multimeter before soldering. You will likely need a level shifter.
                    • F
                      fox
                      I have disassembled the monitor and have seen that I can’t give the signals per gpio.
                      It’s a serial connection and I can’t simulate the protocol.
                      So, is it possible to use the LCD Screen?
                      It’s a m240hw01 v2
                        bhepler Module Developer @fox
                        @fox It’s possible. If you configure your Pi to turn off the signal to the HDMI port, the monitor should shut off automatically. It should remain off until it detects a signal again, whereupon it will turn itself back on.
                        The MotionDetection module can do this for you with a Raspberry Pi camera. Otherwise, there is a module for using a PIR sensor.
