    automatic update module by notification
    12 Posts 6 Posters 3.4k Views 7 Watching
    • bheplerB Offline
      bhepler Module Developer @bdream
      @bdream Another option is to use a tool that will let you remotely log into her mirror from your house. Then when she says that it is displaying the available update, you can remotely perform the steps.There are a few services out there that allow you one or two remote access for free and then you pay for any others beyond that.
      But @sdetweil is correct: the mirror itself is very stable so just disable the update notification. If something breaks, she’ll let you know.
        sdetweil @bdream
        @bdream if the module update adds a feature,
        you don’t care, as u are not using it now
        if the module update fixes a bug
        you don’t care as u probably haven’t seen it
        (else u wouldn’t have deployed the module in such a sensitive environment…)
        I STRONGLY recommend,
        If it’s working, don’t touch it.
        • karsten13K Offline
          karsten13 @bdream
          @bdream said in automatic update module by notification:
          I would prefer having an automatic to update in case it’s notified.
          option1: Adding a new paramter “forceUpdate” to the notification module so that it does the update instead of the notification (someone has to code this)
          option2: Write a bash script which iterates over the module folders doing something like this (in every module folder)
          git reset --hard
          git pull
          [ -f "package.json" ] && npm install
          This script should be executed e.g. daily by e.g. a cronjob.
          As Sam already mentioned this would be the hard way, may its better not to change a running system and ignore the notification, your decision.
            MMRIZE
            I recommend not updating MM or modules unless they work. Just leave them. Update them only when you find some issue or need a new feature.
              bdream @MMRIZE
              @MMRIZE @sdetweil @bhepler @karsten13
              many thanks for your comments, I really appreciate it!
              At first I will disable notification at my mothers MM. Hope there will not be a secure issue I oversee than. But it will anyway be an small one in my mothers environment.
              For me I will play with “play” with the other options you mentioned and will see if this works for a longer time in a good way ;)
              cheers, bdream
                sdetweil @bdream
                @bdream I use TeamViewer to remote access
                install server, start, get code
                then client requires code
                • bugsounetB Offline
                  bugsounet Banned @bdream
                  @bdream , Hi it’s already coded since some year but not published in this forum :beaming_face_with_smiling_eyes:
                  B 1 Reply Last reply Reply Quote -1
                    bdream @bugsounet
                    @bugsounet sounds good!
                    What is the midules name please?
                    cheers, bdream
