    Mirror broken after v2.22.0 upgrade
    29 Posts 4 Posters 10.5k Views 4 Watching
      sdetweil @ecirpnaes
      @ecirpnaes ok, what system are u running on?
      lsb_release-a
      uname -a
      I did the install on pi os, and on Intel Linux.
      what desktop are u running?
      Wayland, x11, ??
      • E Offline
        ecirpnaes @sdetweil
        Distributor ID: Raspbian
        Description: Raspbian GNU/Linux 9.13 (stretch)
        Release: 9.13
        Codename: stretch
        Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
        Honestly not sure what desktop it is running. I usually just putty into it from a windows machine.
        S 1 Reply Last reply Reply Quote -1
          sdetweil @ecirpnaes
          @ecirpnaes ok stretch is too old for this latest electron
          I think u have to move up to buster(release after stretch) as least
          bullseye is the current
          and another one coming soon… this year I think.
          u might be able to backup,/restore using my scripts
          https://github.com/sdetweil/MagicMirror-backup-restore
          and use my script to install latest to restore config to.
          E 2 Replies Last reply Reply Quote 0
          • E Offline
            ecirpnaes @sdetweil
            @sdetweil That sounds about right. It’s been a couple years since I’ve updated my base image. I assumed it was going to come to that sooner or later.
            Thanks for the confirmation. I’ll definitely take a look at your scripts.
              Peter @sdetweil
              @sdetweil said in Mirror broken after v2.22.0 upgrade:
              @ecirpnaes ok, do this
              rm -rf node_modules
              npm install --omit=dev --no-audit --no-fund
              i just did this on my pi4 after upgrading from 2.21
              Great!
              Solved my problem too!
              Thanks.
              Peter
              S K 2 Replies Last reply Reply Quote 1
                sdetweil @Peter
                @Peter awesome!
                • K Offline
                  Knight @Peter
                  @Peter I have done same but in my case only server is running
                    sdetweil @Knight
                    @Knight are u only running server mode on purpose?
                    • K Offline
                      Knight
                      no, I want to run directly, but it is giving the same error
                      /home/pi/MagicMirror/node_modules/electron/dist/electron: symbol lookup error: /home/pi/MagicMirror/node_modules/electron/dist/electron: undefined symbol: gbm_bo_get_modifier .
                      So I run server mode
                      • K Offline
                        Knight @sdetweil
                        I’m getting an Electron error on startup.
                        Specifically… .node_modules/[…]/dist/electron: symbol lookup error: undefined symbol: gbm_bo_get_modifier
                        So I run in server mode
