    Mirror broken after v2.22.0 upgrade
    29 Posts 4 Posters 12.9k Views 4 Watching
      sdetweil @ecirpnaes
      @ecirpnaes ok, do this
      rm -rf node_modules
      npm install --omit=dev --no-audit --no-fund
      i just did this on my pi4 after upgrading from 2.21
      E P 2 Replies Last reply
      • E
        ecirpnaes @sdetweil
        @sdetweil Thanks!
        I had already tried blowing away the node_modules and letting it rebuild doing a standard “npm install”, but hadn’t tried it with omitting the dev only files. That said, I just did it and still no go.
        To be clear, the mirror will run with a “server only” option, so the error is clearly with a library file with electron.
        /home/pi/MagicMirror/node_modules/electron/dist/electron: symbol lookup error: /home/pi/MagicMirror/node_modules/electron/dist/electron: undefined symbol: gbm_bo_get_modifier
        I’ll try a few other things but I guess worse comes to worse, I can pull a clean image and just clone everything down again.
          sdetweil @ecirpnaes
          @ecirpnaes ok, what system are u running on?
          lsb_release-a
          uname -a
          I did the install on pi os, and on Intel Linux.
          what desktop are u running?
          Wayland, x11, ??
          E 1 Reply Last reply
          • E
            ecirpnaes @sdetweil
            Distributor ID: Raspbian
            Description: Raspbian GNU/Linux 9.13 (stretch)
            Release: 9.13
            Codename: stretch
            Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
            Honestly not sure what desktop it is running. I usually just putty into it from a windows machine.
            Reply Quote -1
              sdetweil @ecirpnaes
              @ecirpnaes ok stretch is too old for this latest electron
              I think u have to move up to buster(release after stretch) as least
              bullseye is the current
              and another one coming soon… this year I think.
              u might be able to backup,/restore using my scripts
              https://github.com/sdetweil/MagicMirror-backup-restore
              and use my script to install latest to restore config to.
              E 2 Replies Last reply
              • E
                ecirpnaes @sdetweil
                @sdetweil That sounds about right. It’s been a couple years since I’ve updated my base image. I assumed it was going to come to that sooner or later.
                Thanks for the confirmation. I’ll definitely take a look at your scripts.
                  Peter @sdetweil
                  @sdetweil said in Mirror broken after v2.22.0 upgrade:
                  rm -rf node_modules
                  Great!
                  Solved my problem too!
                  Thanks.
                  Peter
                  S K 2 Replies Last reply
                    sdetweil @Peter
                    @Peter awesome!
                    • K
                      Knight @Peter
                      @Peter I have done same but in my case only server is running
                        sdetweil @Knight
                        @Knight are u only running server mode on purpose?
                        K 1 Reply Last reply
                        • K
                          Knight
                          no, I want to run directly, but it is giving the same error
                          /home/pi/MagicMirror/node_modules/electron/dist/electron: symbol lookup error: /home/pi/MagicMirror/node_modules/electron/dist/electron: undefined symbol: gbm_bo_get_modifier .
                          So I run server mode
                          • K
                            Knight @sdetweil
                            I’m getting an Electron error on startup.
                            Specifically… .node_modules/[…]/dist/electron: symbol lookup error: undefined symbol: gbm_bo_get_modifier
                            So I run in server mode
                              sdetweil @Knight
                              @Knight can you show output of
                              lsb_release -a
                              • K
                                Knight @sdetweil
                                E S 2 Replies Last reply
                                • E
                                  ecirpnaes @sdetweil
                                  My problem is resolved. I upgraded to bullseye and reinstalled the mirror. I used your alternative install script vs cloning manually. It worked flawlessly setting up the mirror and the pm2 autostart. So many thanks for that.
                                  I think I spent more time getting the mirror to rotate properly than anything else. File locations have changed for bullseye vs some of the older versions so it took a little hunting around to get things configured.
                                  But all good now. Thanks again!
                                  • E
                                    ecirpnaes @Knight
                                    @Knight Your problem is the exact same as what I had.
                                    Same error message.
                                    Same outdated OS.
                                    The fix is to back up your config file(s), update your OS to the latest (bullseye), reinstall the mirror software and any custom modules.
                                    Sam has a bunch on scripts in git repo that make this a very simple operation. Took me less than an hour, with the vast majority of that waiting for package files to download.
                                      sdetweil @Knight
                                      @Knight yes sadly the latest electron will not run on 3 year old stretch…
                                        Peter
                                        @ecirpnaes said in Mirror broken after v2.22.0 upgrade:
                                        Here everything works fine now except rotation of the screen …
                                        Somebody have an idea?
                                        I tried display_rotate=1 in config.txt; it looks good but as soon as MM starts the screen rotates back to the left.
                                        Peter
                                          sdetweil @Peter
                                          @Peter use the preferences, top left on desktop, display rotation
                                          P 1 Reply Last reply
                                            Peter @sdetweil
                                            @sdetweil preferences gives the same problem: screens turns back to normal after restarting MM.
                                            I am trying custom CSS now (saw it somewhere).
                                            Keep you informed.
                                            Peter
