    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 27.2k Views 6 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @wishmaster270
      @wishmaster270 OK, you’re welcome.
      Since the thread is also for other developers: I recommend considering my approach, as I consider the other approach (installing to a higher-level directory) to be more error-prone. But it’s a creative workaround.
      • wishmaster270W Offline
        wishmaster270 Module Developer @KristjanESPERANTO
        @KristjanESPERANTO
        The problem with installing it in the module directory is that we need to compile the library against the electron version installed in the MagicMirror project.
        If electron-rebuild is installed in the module directory it might fail to detect the right electron version (which was the cause of the rebuild problems in the past).
        So the right way is to install electron-rebuild in the same project as electron and call it from there.
        It might be worth to think about adding it as a dependency in the main project.
        KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 1
          @wishmaster270 Okay, thanks for the explanation! I haven’t been able to read that anywhere in such clear words and I haven’t dealt with the past problems. Then I withdraw my recommendation because I lack the overview.
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO ah I see
            haven’t heard of @electron/rebuild
            • karsten13K Offline
              karsten13 @wishmaster270
              @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
              installing module stuff in the node_modules folder of mm is a hack and will not work out of the box with a docker setup because this folder is only in the container (you have to map it on the host to get changes there persistent)
              in this case may the best solution
                sdetweil @karsten13
                @karsten13 yes, that’s what I think we come to but doesn’t help any existing broken modules
                  sdetweil @karsten13
                  @karsten13 docker is a pita with this stuff. too much/not enough in the container. which is supposed to be immutable.
                    @sdetweil As a soft step, the broken modules could switch to @electron/rebuild. This should also work for docker.
                    wishmaster270W S 2 Replies Last reply Reply Quote 0
                      @KristjanESPERANTO
                      I have a docker installation running for development here on my notebook.
                      Everytime a module needs “npm install” I exec to the container and run the command in the container cause there will be called the correct npm and node version in the container and not the ones I currently use on my notebook.
                      In this case the directory structure is the same as with a locally installed MagicMirror and the postinstall script will work as excepted.
                      karsten13K 1 Reply Last reply Reply Quote 1
                        yes, will work, but all the changes in the node_modules folder of mm are gone with the next restart of the container …
                          wishmaster270 Module Developer @karsten13
                          @karsten13
                          In case of electron-rebuild this is no problem as it is only required during compile but not at runtime.
                            @wishmaster270
                            o.k., but where are the compile results stored?
                              @karsten13
                              They are stored in the node_modules folder of the module which should be persistent
                              Edit: Do not misunderstand me. In my opinion the best way to solve the electron-rebuild problems of a lot of modules would be to put “@electron/rebuild” as a dependency to “package.json” of MagicMirror.
                              karsten13K 2 Replies Last reply Reply Quote 0
                                @karsten13
                                thats good, so the construction with installing electron-rebuild in mm folder has no side effects and works also in a docker setup.
                                  I don’t have a final opinion on that yet, but if so, we should put it under optionalDependencies as electron
                                  wishmaster270W S 2 Replies Last reply Reply Quote 1
                                    @karsten13
                                    You are right. I think optionalDependencies would be a great solution. Module developers could then add a hint to run npm ci in the MagicMirror directory to their installations instructions.
                                    As the container it self is untouched it should be no problem. It only causes @electron/rebuild to be installed the next time the script is called.
                                      @KristjanESPERANTO but if u look at electron/rebuild after install u call electron-rebuild
                                      still has to be installed in the base node_modules folder…
                                      older unmaintained modules are broken either way. why I had to fork MMM-Buttons.
                                        sdetweil @wishmaster270
                                        @wishmaster270 optional is there so that IF electron is NOT installed, the install does not fail (needed on pi0w at least)
                                        have nothing to do w ci
                                        my script ONLY installs prod, no dev. as 99.5% of users are users not mm developers. has nothing to do w module developers
                                          sdetweil @karsten13
                                          @karsten13 and the postinstall checks for it being there, and if so skips the e-r install.
                                          doesn’t know/care HOW it got installed before
                                            karsten13 @sdetweil
                                            you can use --omit=optional as param for npm install, I use this for my amd64 images because they are run to 99,9% with npm run server so electron is not needed
                                            • 3 / 3
