    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 28.5k Views 6 Watching
    • wishmaster270W
      wishmaster270 Module Developer @KristjanESPERANTO
      @KristjanESPERANTO
      I have a docker installation running for development here on my notebook.
      Everytime a module needs “npm install” I exec to the container and run the command in the container cause there will be called the correct npm and node version in the container and not the ones I currently use on my notebook.
      In this case the directory structure is the same as with a locally installed MagicMirror and the postinstall script will work as excepted.
      karsten13K 1 Reply Last reply
      • karsten13K
        karsten13 @wishmaster270
        @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
        yes, will work, but all the changes in the node_modules folder of mm are gone with the next restart of the container …
        wishmaster270W 1 Reply Last reply
        • wishmaster270W
          wishmaster270 Module Developer @karsten13
          @karsten13
          In case of electron-rebuild this is no problem as it is only required during compile but not at runtime.
          • karsten13K
            @wishmaster270
            o.k., but where are the compile results stored?
            • wishmaster270W
              @karsten13
              They are stored in the node_modules folder of the module which should be persistent
              Edit: Do not misunderstand me. In my opinion the best way to solve the electron-rebuild problems of a lot of modules would be to put “@electron/rebuild” as a dependency to “package.json” of MagicMirror.
              karsten13K 2 Replies Last reply
              • karsten13K
                @karsten13
                thats good, so the construction with installing electron-rebuild in mm folder has no side effects and works also in a docker setup.
                • karsten13K
                  I don’t have a final opinion on that yet, but if so, we should put it under optionalDependencies as electron
                  wishmaster270W S 2 Replies Last reply
                  • wishmaster270W
                    @karsten13
                    You are right. I think optionalDependencies would be a great solution. Module developers could then add a hint to run npm ci in the MagicMirror directory to their installations instructions.
                    As the container it self is untouched it should be no problem. It only causes @electron/rebuild to be installed the next time the script is called.
                      sdetweil @KristjanESPERANTO
                      @KristjanESPERANTO but if u look at electron/rebuild after install u call electron-rebuild
                      still has to be installed in the base node_modules folder…
                      older unmaintained modules are broken either way. why I had to fork MMM-Buttons.
                        sdetweil @wishmaster270
                        @wishmaster270 optional is there so that IF electron is NOT installed, the install does not fail (needed on pi0w at least)
                        have nothing to do w ci
                        my script ONLY installs prod, no dev. as 99.5% of users are users not mm developers. has nothing to do w module developers
                          sdetweil @karsten13
                          @karsten13 and the postinstall checks for it being there, and if so skips the e-r install.
                          doesn’t know/care HOW it got installed before
                          • karsten13K
                            karsten13 @sdetweil
                            you can use --omit=optional as param for npm install, I use this for my amd64 images because they are run to 99,9% with npm run server so electron is not needed
                            T 1 Reply Last reply
                            • T
                              thobach @karsten13
                              @karsten13 What are your thoughts on adding npm install @electron/rebuild --unsafe-perm; \ as part of the container image creation process to https://gitlab.com/khassel/magicmirror/-/blob/master/build/Dockerfile-debian?
                              • karsten13K
                                karsten13 @thobach
                                @thobach
                                I’m trying to keep image size small … but which image are you using? latest or fat?
                                • 3 / 3
