    MMM-PIR-Sensor-Lite not switching off
    11 Posts 4 Posters 3.2k Views 4 Watching
    • N6NGN Offline
      N6NG @sdetweil
      @sdetweil No. are they yours?.. I’ll take a look…
      Dennis
        sdetweil @djlagaffe
        @djlagaffe did u enable debugMode?
        from doc
        debugMode: true
        D 3 Replies Last reply Reply Quote 0
          sdetweil @djlagaffe
          @djlagaffe also note the info in the doc after the options table about problems with bullseye and/or buster
            djlagaffe @sdetweil
            @sdetweil : I did check with the scripts and the PIR itself works. I have also activated the countdown timer, thus the communication between the PIR, the script and MM in general works. What I do not see is that the command to switch off the screen is executed (or even sent).
            I have verified the script and the command to check whether the command itself works on my installation, and yes, it does.
            So it should be something not triggering the switch-off / on command. However I have not been able to put my finger on it yet…
              djlagaffe @sdetweil
              @sdetweil : yes, however no luck or any log entry at all in pm2 logs mm - am I looking in the wrong place?
                djlagaffe @sdetweil
                @sdetweil Sorry, one add-on no debug messages either in the logs, nor via npm run start:dev
                  djlagaffe
                  Found the error - xrandr needs a sudo in front, otherwise it doesn’t execute.
                  bheplerB 1 Reply Last reply Reply Quote 2
                  • bheplerB Offline
                    bhepler Module Developer @djlagaffe
                    @djlagaffe - I was able to get it working with xrandr with a small modification to the node_helper.js file. I’ll submit a PR soon.
