    v2.22.0 | default calendar: no symbols with customEvents
    29 Posts 7 Posters 19.1k Views 7 Watching
      sdetweil @JDIBBY
      @JDIBBY can you use the link I posted about the dev console and see what symbol class and name was used the those elements?
      • karsten13K
        karsten13 @sdetweil
        there was a change concerning symbols, see https://github.com/MichMich/MagicMirror/pull/2949/files
        this should be backward compatible in normal setups but I don’t know how this is compatible with customEvents.
        Did you try something like
        ..., symbol: 'fa-solid fa-megaphone' ... or
        ..., symbol: 'fas fa-fw fa-megaphone' ... ?
          sdetweil @karsten13
          @karsten13 but he should not have to use the fa- prefix on megaphone, cause its in the setting
            @JDIBBY I changed one of my test cal setups to use custom events, copying your data but changing the trigger text
                      url: "http://localhost:8090/modules/default/calendar/woot.ics",
                      symbol: "calendar",
                      color: "#efefef",
                      name: "Rags Calendar",
                      customEvents: [
                        { keyword: 'Weekly', symbol: 'file-signature' },
                        { keyword: 'Every', symbol: 'champagne-glasses' },
            and see this
            kaiK 1 Reply Last reply Reply Quote 0
            • kaiK
              kai @sdetweil
              @sdetweil looks great - that’s the way I’d like to have it. :grinning_face:
              So you didn’t specify a symbol class for the customEvents at all? I have had no success with this so far…
                sdetweil @kai
                @kai no, exactly as I posted. are you sure those are the phrases in your calendar subject?
                I had a problem once before, and had Two spaces between words in the calendar event, and only one in the events stucture…
                  DaveChild
                  I’ve been having the same problem. In mine the fas fa-fw fa- prefix was missing, so I changed my config to this:
                  customEvents: [
                      {keyword: "Games", symbol: "dice fas fa-fw fa-dice"},
                      {keyword: "Rugby", symbol: "running fas fa-fw fa-running"},
                      {keyword: "Guitar", symbol: "guitar fas fa-fw fa-guitar"}
                  I duplicated the “dice” at the start so it keeps working when the bug is fixed. And the icons appear now.
                  Calendar screenshot showing custom icons
                    sdetweil @DaveChild
                    @DaveChild hm… that is the symbolPrefix variable in 2.22
                    D L 2 Replies Last reply Reply Quote 0
                      DaveChild @sdetweil
                      @sdetweil I’ve not delved far into the code but it looks to me like the symbolsForEvent function in calendar.js is getting the default symbol with the default class, but then overwriting that default with the symbol from customerEvents - but not applying the default class to it.
                      This might be fixed with applying this.getCalendarPropertyAsArray to ev.symbol in the line symbols[0] = ev.symbol;.
                      I’d do a PR myself but I have nowhere near enough experience tinkering with MagicMirror to be pushing code to a default module :). But I think that’s where the problem is, and my solution will work around that issue crudely for the moment.
                        sdetweil @DaveChild
                        @DaveChild cool. I’ll give that a look
                          DaveChild @sdetweil
                          @sdetweil I did a quick PR anyway, even if it’s not perfect, it’s better there’s a starting point for a fix than make someone repeat tracking it down to where I got to.
                          • L
                            lmhmm @sdetweil
                            @sdetweil Yes I’ve got the same issue after upgrading to 2.22 no symbols even trying solution here. Be nice to get this resolved
                              sdetweil @lmhmm
                              @lmhmm Dave found it and provided a fix for next release. (April 1)
                              you could look at what he did and change your code,
                              of git pull and check the develop branch. see the instructions pinned to the top of this topic about testing fixes.
                                sdetweil @DaveChild
                                @DaveChild awesome. I saw all the GitHub traffic. great work
                                • L
                                  lmhmm @sdetweil
                                  @sdetweil I really don’t understand the answer so will just wait for the next release. Or do I just hit pull the default calendar module? Not sure how to apply fix.
                                  • kaiK
                                    kai @sdetweil
                                    Hi @DaveChild, @sdetweil,
                                    thank you very much for your effort and your research!!!
                                    I’ll use @DaveChild’s prefix solution until the next release; the custom icons are now displayed within the calendar.
                                    Many, many thanks to you and all who so tirelessly develop the MM and keep it alive!
                                    May the code be with you
                                    -kai
                                      sdetweil @lmhmm
                                      @lmhmm you cannot just update one default module. it’s all or nothing.
                                      mm uses the git source code mgmt system
                                      this provides for different version of code concurrently.
                                      mm uses the master branch as the current running code
                                      and the develop branch to accumulate updates between releases.
                                      if u follow the steps in the test fixes topic
                                      https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                      you can pull down the develop branch and try it out.
                                      if you don’t know what this means and cannot try it then u have to wait. mm releases a new version every 90 days
                                      • karsten13K
                                        karsten13 @sdetweil
                                        @sdetweil said in v2.22.0 | default calendar: no symbols with customEvents:
                                        the fix is not on develop because it is not merged yet but it should not take a long time …
                                        • L
                                          lmhmm @karsten13
                                          @karsten13 Thanks I’ll wait for the solution rather than totally mess my mirror up …
                                          • karsten13K
                                            karsten13 @lmhmm
                                            @lmhmm
                                            meanwhile the fix is merged on develop. You can try the develop branch or wait for official release in April.
