    Restarting MM² when config.js file changes
    6 Posts 5 Posters 6.9k Views 6 Watching
      shbatm Module Developer
      This has been helpful for me, but I didn’t see it mentioned anywhere, so I thought I’d share. For anyone looking for a simple way to automatically restart your MM² when you change the config.js file:
      Note: This assumes you are using pm2 to start the server, as described here: Auto Starting MagicMirror
      1. Create a file in the same location as your mm.sh script called mm.json.
      2. Paste the contents of this gist into the file (adjust if needed for your setup).
      3. Run pm2 stop mm && pm2 delete mm to stop & remove the current mm script.
      4. Run pm2 start mm.json to restart MM. Now any time you change config.js, pm2 will automatically restart the process.
      5. Run pm2 save to save your changes for the next reboot.
      That’s it!
      Originally inspired by: Restart Mirror?
      L 1 Reply Last reply Reply Quote 3
        For those that do a lot of testing, something I’ve found very useful as well: extract the config.js file out into it’s own git repo; then just switch between branches when you want to test something, that way you don’t break your “main” config file.
        cd ~
        mkdir mmConfig
        cd mmConfig
        git init
        mv ~/MagicMirror/config/config.js ./config.js
        ln -s /home/pi/mmConfig/config.js /home/pi/MagicMirror/config/config.js
        git commit -am "Initial Commit"
        git checkout -b testing
        # Change and test config.js without fear of breaking it!
        # Use checkout -f master to switch back to your main branch
        • W Offline
          William
          Hello !
          I’ve followed your tutorial and it seems to work. For example my MM starts on boot.
          But when my MM is open, if I press Alt+tab to open and modify my config.js file, nothing is happening (it is not restarting).
          I don’t know why, do you have any idea ?
          Thank you !
          Edit: After a reboot, this is working ! Ty
          Edit2: There is a way to not completly rebooting it ? I mean doing the same thing as pressing CTRL + R, so the mirror reboots but stays on a black screen (instead of going back on the Desktop)
          Edit3: If I do “pm2 stop mm.json” to stop the process and then start it again doing “pm2 start mm.json” then If I modify the config file, this is not working anymore
          • BKeyportB Offline
            BKeyport Module Developer
            Wow. Cool idea.
            • L Offline
              looolz @shbatm
              @shbatm Just want to tell you that I’ve googled this thread every single time I’ve setup a new mirror from scratch, and still love it. Thanks for making a post almost 6 years ago that still has all the info and works!
                sdetweil @looolz
                @looolz my install script sets up to monitor config.js. does sometimes…
