    Restart Mirror?
    5 Posts 3 Posters 27.2k Views 2 Watching
      Achatos
      Hey there! I got the Mirror up and nicely running.
      Now I am playing around with the config file. However I can’t seem to figure how to either update or restart the Mirror App.
      I have it starting on boot. So I don’t want to reboot everytime I make a change in the config.js.
      When I cd to the MagicMirror directory and type
      "npm restart
      I get this:
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “restart”
      npm ERR! node v6.9.4
      npm ERR! npm v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.0 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      Any advice?
        broberg Project Sponsor
        if you are working directly on the pi, then ctrl+R reloads the page.
        via ssh somebody else has to chime in, since I don’t use that
          Achatos
          Thanks for the reply. I am indeed using SSH…
          • I Offline
            in_a_days @Achatos
            @Achatos
            Are you running pm2? If so,
            pm2 restart mm
            will restart your mirror software. Otherwise use
            DISPLAY=:0 npm start
            from the MagicMirror folder and it will start up.
            EDIT: Just realized this last suggestion is only applicable if you don’t have the MM software already running.
            What ship would bear me ever back across so wide a Sea?
              Achatos
              “pm2 restart mm” works like a charm.
              Much obliged! :)
