    MMM-WeatherChartD3
    5 Posts 3 Posters 1.5k Views 4 Watching
      Matuki Module Developer
      Description:
      This module displays a chart using any weather provider. It can display temperature, feels like temperature, precipitation, snow and weather icons. It uses the D3.js library.
      Full list of elements that can be displayed:
      • icons of weather
      • day/night separation
      • temperature
      • min/max temperature
      • feels like temperature
      • precipitation
      • snow
      • humidity
      • wind
      • Only with a specific/modified weather provider:
        • pressure
        • precipitation probability
        • pollution
        • UV
      All curves can be styled using CSS
      Screenshots:
      Download:
      https://github.com/seb-ma/MMM-WeatherChartD3
      • M Matuki referenced this topic on
        MajorC Project Sponsor @Matuki
        @Matuki
        Hi I tried to use your module.
        Followed your instructions to install from github. Works well.
        Than I copy past the config, add position, my apiKey, lat and lon.
        But I still have now a black MM.
        Any idea where to start looking. The MM is working fine if I delete the MMM-WeatherChartD3 lines in the config.
        			module: "MMM-WeatherChartD3",
        			position: "bottom_right",
        				updateInterval: 10 * 60 * 1000,
        				initialLoadDelay: 5000,
        				weatherEndpoint: "/onecall",
        				apiKey: "3e349d84feb10771d8c4bf34cde00000", //i changed to a dummy key
        				type: "full", // Possible values: hourly, forecast (=daily) or specific value `full` which is a join of data from hourly+daily
        				lang: config.language,
        				lat: 52.554000,
        				lon: 13.463000,
        				units: config.units,
        				locale: config.locale,
        				d3jsVersion: "7", // can either be in format "7.4" or even "7.4.4"
        				title: "Weather Forecast",
        				height: 300,
        				width: 500,
        				iconSize: undefined, // in px or undefined to define automatically at first call
        				iconURLBase: "https://raw.githubusercontent.com/erikflowers/weather-icons/master/svg/",
        				hoursRatio: 0, // Ratio of fetched hours in graph (useful for openweathermap onecall that gives 48h with 1h precision) - 0 or undefined to ignore
        				showIcons: true,
        				showNights: true,
        				showTemperature: true,
        				showMinMaxTemperature: false,
        				showFeelsLikeTemp: true,
        				showPrecipitationAmount: true,
        				showPrecipitationProbability: true, // Only used when showPrecipitationAmount == true
        				showSnow: true, // if false: snow is included in precipitations
        				showPressure: true,
        				showHumidity: true,
        				showWind: true,
        				showAQI: true,
        				showUVI: true,
          sdetweil @MajorC
          @MajorC see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/
            MajorC Project Sponsor @sdetweil
            Log says, that:
            is not right?!?
              sdetweil @MajorC
              @MajorC looks like this is a javascript change
              https://github.com/MichMich/MagicMirror/issues/2863
